slip on
Old Dec 9, 2006 | 11:04 PM
edcbr's Avatar
Default slip on
if i was to add a slip on exhaust on a 06 rr would i
need to do anyting else to keep the corect back pressure
correct???
thanks
Old Dec 9, 2006 | 11:15 PM
bushmasterAR15's Avatar
Default RE: slip on
No
Old Dec 10, 2006 | 12:57 AM
mannyrios's Avatar
Default RE: slip on
Add a power commander
Old Dec 10, 2006 | 01:08 AM
edcbr's Avatar
Default RE: slip on
ORIGINAL: mannyrios
please excuse my ignorance but what exactly does a power commander do??
thanks for the info.
Old Dec 10, 2006 | 01:11 AM
mannyrios's Avatar
Default RE: slip on
From their webiste. Very good question!
Power Commander
PRODUCT INFO
The PC is a fuel injection and adjustment unit that plugs "inline" with the bikes' stock ECU.
The PC uses original equipment style connectors so that no splicing or cutting of the harness is required. Most installations take less than 15 minutes, some as little as 5 minutes.
Changes are made to the bikes fuel curves via the PC's onboard microprocessor. Using this technology we are able to offer a large area of adjustment without making any permanent changes to the bikes' ECU (electronic control unit).
Removing the PC returns the bike to its previous stock condition. The Power Commander can be ordered preprogrammed with a your choice of several settings, based on the modifications to your bike. The unit also comes complete with software and cable link that allows you to change between different maps or make adjustments to a map file.
http://www.powercommander.com/
Old Dec 10, 2006 | 01:23 AM
edcbr's Avatar
Default RE: slip on
thanks for the info mannyrios
i really do appreciate it.
keep the rubber side down[sm=icon_rock.gif]
Old Dec 10, 2006 | 01:26 AM
mannyrios's Avatar
Default RE: slip on
ORIGINAL: edcbr
Not a problem. Anytime. That's why we're all here for... ask and you shall get an answer!
Old Dec 10, 2006 | 02:00 AM
D2VW14_20's Avatar
Default RE: slip on
You dont NEED a power commander. It will run fine without one if it is just a slipon. It may run a little rich for a while, but not anywhere near enough to effect anything.
However, if you do get a power commander, you will get more out of your slip on, however, if you are going to spend that type of money, $400+ on and slip on and $300+ on a PCIII, you might as well get a full system.
But if you just put on slip on you shiouldnt have any problems without a PCIII. There are A LOT of people that are just running a slip on and nothing else. There isnt a big enough difference from stock to make the A/F ratio enough to effect anything or hurt anything. But if you have th eectra $300 and wht to buy a PCIII go for it.
Mehmed
Sep 10, 2012 08:11 PM
Gsxr_eater
Sep 28, 2008 01:00 AM
Diablo Runner
Dec 9, 2007 05:18 PM
