rear tire hip hop
Old Sep 19, 2006 | 04:23 AM
TwistedCBR's Avatar
Default rear tire hip hop
Rear feels like a nail in tire but not all the time, only sometimes.
My opinion:
Best case scenario--flat spot
Worst case scenario--wheel bearings
Any ideas where to check
Mind you, I have a 5500 mile ride in a few days...few means reallllll soon
Old Sep 19, 2006 | 05:26 AM
dwhite645's Avatar
Default RE: rear tire hip hop
Don't really understand the symptoms, but my best guess as I understand it would be to check chain slack, squared off tire, out of round tire, out of balance, out of alignment, etc...hard to say.
Old Sep 19, 2006 | 11:29 AM
bobjoezx's Avatar
ya sounds lik eu need to check out the rear.. all the adjustments and tire.. if the tire is old and such get a new tire and make sure you align it correctly if you do it yourself, also check your chain and things, did u tighten your axle nut to tight last time, because if you go to far you can crush the bearings and make their life very short, check that all out, not that expensive for new bearings, go get a new tire, slap some new bearings in there adjust your chain and see what happends
Old Sep 19, 2006 | 12:40 PM
TwistedCBR's Avatar
The road-attacks have 7k on them but still have 2-3k left of tread. The chain was tightened about 3 weeks ago (not much riding since) and I do remmeber checking and rechecking all the nuts and that went fine. The tires have 40-55% interstate riding on them so I and sure they've taken a beating in the middle. I don't wanna replace them now and have to replace them when I get to cali but I wish their was an easy way to determine if it was just the bearings. I know what eventually happens as time goes on with bad rear wheel bearings (**** locks up and becomes very wobbley)
Old Sep 19, 2006 | 02:20 PM
TwistedCBR's Avatar
Told might be swingarm bearing?
Old Sep 19, 2006 | 02:26 PM
ddvs's Avatar
Is there any play from side to side on the rear tire?
Old Sep 19, 2006 | 03:05 PM
TwistedCBR's Avatar
Less I had a lift or stand I don't know if I would be able to give you a 100% answer. It feels like it while riding but with bike parked I don't think I'de be able to determine that
Old Sep 19, 2006 | 03:27 PM
ddvs's Avatar
yeah thats true, have you tried lubing your chain or anythign simple like that? Maybe your chain is too tight?
Old Sep 19, 2006 | 04:53 PM
TwistedCBR's Avatar
Yup I adjusted the chain a couple hundred miles ago and it should be fine, I made sure to leave a little slack in it.
I religiously lube/wax the chain as well as cleaning it--cuz it looks good when it's cleaned
TwistedCBR's Avatar
