Great I got your eye. this is sort of a cross post but I have a problem with a 99 900 and no one has awnsered it . You can read MYoriginal post in that section if you think you need more info. my question is this, when a pressure plate is put in the basket should the lifter be able to fall back in the basket or should it be snug in the plate. it is my understanding that when you pull the lever the lifter pulls the plate out and against the springs and should have force pulling it back to be returned, so should I feel more than the little return spring out side the case pulling it back? thanks for the input
