How much to get carbs cleaned?
Old Feb 9, 2009 | 09:41 PM
smitty911's Avatar
Default How much to get carbs cleaned?
From a katana 750. We took them off so we could take them up to the bike place and get cleaned but they said they have to be on the bike or they wont touch them because they have to check if they are firing right. and they also said the base price is around $550 but that is just an estimate!?
Does that sound right to you guys? i thought it would be like 100 to get them cleaned. I was way off lol
Old Feb 10, 2009 | 05:57 AM
justasquid's Avatar
definately clean them yourself. You have them off already. Its just a matter of removing the float bowls, pulling the jets and cleaning them. Also, remove the floats so you can make sure the needle and seat are good and clean.
I think the main reason they charge 550 is its all based on hours. So if the shop charges say 80 an hour, they are estimating almost 7 hours of labor. removing the carbs, cleaning them, reinstalling them, sycning them..... I can see the hours adding up.
You and I both know that it doesnt take that long, especially for a seasoned mechanic. But more than likely, they have a book they go by that suggest how long it should take to do a certain task and thats how much they charge. But getting it done for 100 bucks would be extremely cheap.
If I were you, I would clean them myself. Then reinstall them. If you have any running issues, set up an appointment to have them sycned. that would save you some time and money. Its not as hard as it sounds. You actually have the hard part already done in removing them. Cleaning them is the easy part.
Old Feb 10, 2009 | 07:05 AM
bwayers's Avatar
dude you're looking at probably $100 to get a single carb bike cleaned up
if i remember right my shop charges around $250 or so for a 4 carb bike
also prices are generally setup by a manufacturer on things like this. I know Honda sets our hourly rate and gives a base price for things like this and tire changes etc
Old Feb 10, 2009 | 11:31 AM
smitty911's Avatar
Okay i will run it by him and see if he wants me to clean them. I know how to but i dont think he trusts me lol (i cleaned mine before)
is there any trick to get the screws out of the float bowls with out stripping them? There on there pretty tight.
Old Feb 10, 2009 | 11:32 AM
scastillo13's Avatar
i got mine cleaned and synch, oh and tank washed for $220!! Just gotta look around and see who is capable of doing the job if u cant or dont have the time...but they are right, toughest part is getting them out.
Old Feb 11, 2009 | 07:29 AM
NY Erion929's Avatar
We charge $149 plus any parts needed. I work at a Dealer in NY
Old Feb 11, 2009 | 03:00 PM
hellboytt's Avatar
I cleaned and synced mine, fairly easy deal, take them apart, clean them, put them back in and then you just need 4 vac gauges to sync them.
Old Feb 11, 2009 | 04:37 PM
Kikepiz's Avatar
110 for:
New spark plugs.
Cleaning carbs.
New oil.
new filters.
cesarsanch2
Nov 8, 2012 10:32 PM
MikeInCtown
Aug 18, 2011 08:25 PM
ganzey
May 19, 2011 06:45 AM
l0st1
Jul 14, 2009 12:20 PM
hikerduane
Mar 7, 2006 12:12 AM
