Gas
Old May 15, 2010 | 11:27 AM
kowen1208's Avatar
Default Gas
My service manual says to use 86 octane or higher, which means mid-grade would work. I've been putting 91 octane from Chevron in it.
What kind of gas do you use and what kind of bike?
Old May 15, 2010 | 12:27 PM
Shadow's Avatar
You can use anything available from a pump in your area.
Higher octane doesn't mean more performance, unless you have the mods to make use of the boosted octane.
I'm running 95 unleaded in a 1000F.
It's the lowest we have.................
Old May 15, 2010 | 01:20 PM
kowen1208's Avatar
95 is the lowest? Wow. 91 is the highest we have.
Old May 15, 2010 | 03:02 PM
txsmainevent's Avatar
i put mid grade (89) in mine last night. didnt feel a difference what so ever. tank stayed cool as **** the whole time it was like havin ac! i been runnin premium since i have owned bikes but ill post if i run into any issues. also i have a buddy wit a 99 900rr who has run low grade the entire time and its still a beast....ill take the savings on chosin a lower octane
Old May 15, 2010 | 07:31 PM
chuckbear's Avatar
Isn't your "95" based on RON though Shadow?
Old May 15, 2010 | 07:53 PM
justasquid's Avatar
you should always run closest to the reccomended octane without going under, since thats what the engine was designed to run. Run higher octane, and loose power, Run lower octane, and run the risk of pre-ignition. If 86 is the minimum, run 87. You'll get the best out of your engine.
Old May 16, 2010 | 07:02 AM
Hoosier1104's Avatar
There is a station on the west side of Indy that has race fuel on a pump, 109 (I believe). I am going to run a tank or 2 through before I switch to mid grade.
Old May 16, 2010 | 07:30 AM
Seafordguy's Avatar
Foreign Octane measurements are different.
There is a thread on this in the 600RR section - it is even titled "Gas" - read it.
Old May 16, 2010 | 09:53 AM
frozenpoet's Avatar
when I run the low grade I get popping and what not, but mid grade things clear up, so that's what I've been running.
Old May 16, 2010 | 09:58 AM
Kuroshio's Avatar
Actually if we can get away from the octane argument, I'd like to hear what brand gas everyone uses.
There's a Getty station down the block from my apt. Not too sure about their gas though. My gf's car and my bike ran chitty after getting gas from them. Different weeks so I doubt it was simply a bad batch of gas.
