Don't fly with FLYOU
Old Nov 28, 2007 | 08:00 PM
rvizzle's Avatar
Default Don't fly with FLYOU
So I found a video of FLYOU landing a plane. SCARY. He's the 5th aircraft.
http://www.youtube.com/watch?v=4RdxU...eature=related
Old Nov 28, 2007 | 08:10 PM
alekinci's Avatar
Default RE: Don't fly with FLYOU
dang.. drifting with a car is hot,drifting with a plane is unworldly!
Old Nov 28, 2007 | 08:29 PM
redzintimidator's Avatar
thats f'in crazy...i cant imagine trying to land in a crosswind. cant wait til some of the pilots in here have somethin to say about this
Old Nov 28, 2007 | 08:34 PM
voodoochyl's Avatar
Retired Moderator
ORIGINAL: rvizzle
Buahahahaha!!! Me no fly with Flyou, now!!!
Old Nov 28, 2007 | 09:16 PM
SpiritRR's Avatar
I'll fly with him anytime.
Did you guys even read the title? Cross Winds They're a real bitch.
I saw no loss of control, and I'm sure once the pucker factor let up, his seat cushion slowly came back into view...he adjusted his aviators...and kept going.
Good job FLYOU.
Old Nov 28, 2007 | 09:19 PM
voodoochyl's Avatar
Retired Moderator
^^^ Smarty pants ! I know nothing about flying, but I am quick to jump on the "bashwagon"...
Old Nov 28, 2007 | 09:24 PM
WhiteDealershipRice's Avatar
Yep, landing in a heavy crosswind is one of the most unnerving experiences you can have, and it takes an ungodly ammount of skills to get it right.
Depending on how heavy the crosswind component is You're bassically aproaching the airfiels on a sideslip, looking through the side window at where youre going while maintaining the aircraft on the glideslope, which is a lot steeper than normal because of hte same crosswind.
At the last minute, when you're about to flare the aircraft to touch down, you have to simutlaneously kick the rudder to bring hte nose in line with the runway, and lift the wing that's down wind slightly to keep the aircraft from drifting out of the runway.
You touch down on the upwind main gear first, and float the downwind side for a bit until you scrub off enough speed.
On heavy jets, you also apply the thrust reversers, and evry spoiler on the wings to increase drag, and eliminate as much lift from the wings as you can, but you don't touch the brakes untilboth main gears, and the nose gearare solidly on the ground.
Talk about being task saturated!!
Hell, a lot of aircraft aren't even flyable in those croswind conditions.
I also saw a couple of go-arrounds there.
GOOD FOR HTE PILOTS!! If the landing doesn't seem right, swallow your pride and go the hell arround, better to screw up the pattern, than to bend a jet because you "must get it on the ground"
Old Nov 28, 2007 | 09:28 PM
VP's Avatar
VP
ORIGINAL: SpiritRR
Good job FLYOU.
wait a second... am I wrong or wasnt it a joke about it actually being FlyYou
Old Nov 28, 2007 | 09:30 PM
^^ Naw, FLYYOU doesn't actually fly, he's just so ugly the ground repels him...
Old Nov 28, 2007 | 09:32 PM
Kewl Breeze's Avatar
Retired Moderator
Here's a clip of his passengers.
