Bug guts
Old Sep 23, 2007 | 12:26 PM
invader_zoom's Avatar
Default Bug guts
So my question is how do you guys/gals clean the bug guts off your helmets....I use invisible glass for the shield; that works fine.
However I just can't get the little buggers (pun intended) out of the vents and crevices...I thought of useing a tooth brush but that seems as if the bristles would be rather hard on the finish.
Old Sep 23, 2007 | 12:39 PM
D2VW14_20's Avatar
Default RE: Bug guts
I usually use a microfiber towel, and a toothpick to get in the crevices.
Old Sep 23, 2007 | 12:40 PM
SpiritRR's Avatar
Lemon Pledge. Let it penetrate their little carcasses for a second then gently use a new soft-bristled toothbrush. Yet another reason to buy the best helmet you can afford, the clear coat won't be hurt by it.
Old Sep 23, 2007 | 05:07 PM
bushmasterAR15's Avatar
Wtet, Hot, Hot rag and let it sit on there for a while, then use your chemical of choice.
Old Sep 23, 2007 | 10:29 PM
zerochickenstrips's Avatar
Soap and water, alcohol on a Q-tip for the small areas.
Old Sep 23, 2007 | 10:30 PM
N8 Dawg's Avatar
windex...
Old Sep 23, 2007 | 10:38 PM
Wildcat's Avatar
ORIGINAL: N8 Dawg
windex...
Same here
Old Sep 23, 2007 | 10:57 PM
Nauree's Avatar
Your suppost to clean your helmets??????
Old Sep 24, 2007 | 01:57 AM
Blue Fox's Avatar
Retired Moderator
I put Rain-X all over my helmet, and the bugs usually slide right off. For the ones that get stuck in the vents............that PC can-o-air stuff works great to blast them out.
Red Baron
Jun 5, 2014 11:41 AM
badrhino
The Hurricane Saloon
Aug 8, 2013 10:32 PM
asides
F3 Wanted
Aug 26, 2010 01:02 AM
atom
Jan 14, 2007 08:03 PM
