bike question
Old Aug 15, 2007 | 09:10 PM
118367s's Avatar
Default bike question
friend of mine took off his stock pipe and put it back on now his bike wont start can any one help with out going to dealer
Old Aug 15, 2007 | 09:16 PM
HAVOC's Avatar
Default RE: bike question
[:@]... can you provide some simple background info PLEASE !
Old Aug 15, 2007 | 09:17 PM
kodiak1122's Avatar
Pour a gallon of water down the pipe check for leaks. j/k
Can you elaborate on not starting?
What kina bike?
Does fuel pump kick on?
Are plugs fouled?
Kill switch on?
Battery charge ok?
Does starter turn?
Why did he take it off and put it back on?
Gas valve turned on?
Old Aug 15, 2007 | 09:26 PM
118367s's Avatar
2006 kawi 650 ninja, bat charged,no gas vale acts like its gonna start like its out of gas but has gas
Old Aug 15, 2007 | 09:28 PM
kodiak1122's Avatar
ORIGINAL: 118367s
2006 kawi 650 ninja
Sorry can't help ya!!
Old Aug 15, 2007 | 10:06 PM
rmr1923's Avatar
ORIGINAL: 118367s
so ALL he did was remove the stock pipe, put it back on, and it won't start? forgive me for asking, but it sounds to me like something else had to have been removed for something like this to happen. i don't have a lot of knowledge on the Ninja, but perhaps you or your friend might post some questions on a Kawasaki owner's forum? i'm sure guys who own the same type of bike might be able to help because they've probably run into similar problems. i found a good forum a while back when i was asking around about the Z1000 but i've lost the link. tell your friend to retrace his steps, everything he did when he removed the pipe, and i'm sure he'll find something small (and seemingly insignificant) that might be causing this. sounds to me like a problem with the fuel pump. i'm not sure about the Ninja, but i can hear the pump on my 929 turn on when i turn the ignition on. most cars with electric fuel pumps do this too to prime the line, to make sure there's fuel in there to start the engine, so tell him to check out the fuel pump first.
Old Aug 16, 2007 | 06:17 AM
pacemaker's Avatar
Kill switch on !!!!
Old Aug 16, 2007 | 11:33 AM
demonchild's Avatar
is the starter turning?
Old Aug 16, 2007 | 12:59 PM
118367s's Avatar
yep every things pluged in and truned on still nothing
Old Aug 16, 2007 | 08:17 PM
kodiak1122's Avatar
So, how about:
Pinched fuel line,
Clogged fuel line,
Clogged fuel filter,
Carbs ok or fuel injector injecting?
Nothing in the pipes when put back on?
Help us help you.
