Newbie here.... Question on the carbs?
Old May 16, 2017 | 04:17 PM
pgerb4486's Avatar
Hey guys, first post so I'm sorry if it's in the wrong spot.
I'm having an issue as well. I did the "poor man's" carb clean by spraying carb cleaner into it. On one of the carbs, the cleaner runs through it and leaks out of the gasket above the oil pan. This is my first bike so I'm still learning, but that just sounds bad! Any thoughts on what could be going on?
1998 Honda CBR F3
Other issues:
1) When I pull the throttle all the way on the highway the bike bogs down and I lose RPM's
2) The radiator fan doesn't seem like it's kicking on when it should
3) Coolant boils over into the reservoir/doesn't seem like system is working properly
4) Bike shoots between 12 - 13 volts from the rectifier to the battery. I found burnt out wires where the stator connects to the wiring harness, I think the stator needs to be replaced and I need to figure out the best way to splice out the burnt wires (a new harness is $350, this bike is worth less than $1k. Maybe just $500. Doesn't make sense to buy a whole new harness.)
Kook87
Mar 15, 2012 05:24 PM
Passnby
Oct 27, 2008 12:25 AM
Lotsokids
Feb 24, 2008 05:17 PM
Nismo6RR714
Feb 8, 2007 10:09 PM
