need electrical help!
Old Sep 24, 2010 | 09:16 PM
treydeluxe's Avatar
Default need electrical help!
i have a 97 f3 and i know by now how bad they are at burning up regulator/rectifiers, i am on my 4th one. i read on a forum where i need to move my R/R where it can get more airflow to cool it down. i purchased a new R/R and put it on and nothing happens. i checked my battery and it has a full charge but when i switch my key no lights come on or anything at all. all the fuses are good. what the heck is going on??
Old Sep 24, 2010 | 09:40 PM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Hello and Welcome to the CBR Forums!!! I know mine is not an F3 but I do have a main fuse under my seat close to the battery. You didn't say when you turned the switch on if you had any lights, that came on. Hope this helps you out some. If you need any more advise, feel free to ask. You might want to check the F3 section and maybe post your question there also, It would more likely be looked at by more F3 riders.
Good luck and Ride Safe...
Old Sep 24, 2010 | 10:10 PM
kilgoretrout's Avatar
Administrator - Retired
Welcome to the forum, trey.
Sounds to me like the main fuse is blown. It's a stand alone fuse that's not with the others.
HERE is a thread that should explain it.
Now on to the reg/rec. If you've replace 4 of them.... I'd be looking at the stator. Something isn't right if you're going through r/rs like that.
If you need a service manual for you bike, you can download one HERE <--link. It will show you how to test your stator and r/r voltage, etc.
Good luck.
Old Sep 26, 2010 | 12:13 AM
treydeluxe's Avatar
Default thanks!
thanks! that was it. i checked the fuse under the seat because i was curious what is was but i checked the spare fuse and ofcourse because its the spare it was fine and i figured it was fine. when i popped the red coupling off i found the burnt fuse!!. fired up the first time!
Old Sep 26, 2010 | 09:31 PM
No problem, man. Glad you got her back up.
kani73
Jul 31, 2011 04:25 PM
zapp109
Apr 1, 2010 12:18 PM
drown42
Aug 26, 2009 04:06 PM
skitzofrenzy
Sep 22, 2008 04:21 PM
travsstuff
Dec 4, 2007 11:51 PM
