honda cbr 600 f3. light on cuts the bike out
Old Mar 5, 2023 | 10:10 PM
dannoxyz's Avatar
Good job tracking that down!
Darn plastic parts shouldn't be used in fuel system!
Old Mar 6, 2023 | 08:25 AM
Good spot, fingers crossed
Old Mar 11, 2023 | 07:26 AM
josh8412's Avatar
easy fellas you all had the snow.
I have taken carbs off the bike,
will start strip down.
Then clean and replace rubber seals , replace plastic T piece with metal.
1st of all will open them up and see what I find.
take care guys, speak soon.
Old Mar 11, 2023 | 07:31 AM
josh8412's Avatar
Old Mar 11, 2023 | 10:21 AM
dannoxyz's Avatar
Is that hose connected to sync screw?
Old Mar 13, 2023 | 02:15 PM
Nah, it just looks like that. It's the Idle Adjustment cable. It's got a thick black sleeve that looks like a vacuum hose on it.
Old Mar 13, 2023 | 09:46 PM
dannoxyz's Avatar
Ah very good! I've seen vacuum hose attached to that screw before. Very odd.
Old Mar 29, 2023 | 11:46 AM
Halftonmum's Avatar
Hello mate, where would you find these brass T pieces? Seen some on fleabay but not sure if they're the right size
Old Jun 5, 2023 | 10:35 AM
josh8412's Avatar
Default Late up date
hi gurus sorry for the late reply on the cutting out update.
long story short guys it's was the fule pump.
the fule pump couldn't deliver the fule need.
so now have a Mitsubishi racing pump
I cleaned the carbs replaced float pin
bike runs better than ever before.
thank you all and thank you for your time
blessings to you all
Old Jun 7, 2023 | 10:22 AM
josh8412's Avatar
Default brass T piece
the fule T piece I think off top of my head is a 5mm and the air piece is 8mm.
double check I no I am replying late sorry 😐.
once you know the size the important thing to take note is the rubber 0 rings.
Make sure they suitable for petrol! if not then they will perish causing major fule Leake NOT GOOD.
Mossyoak11
May 1, 2021 06:20 PM
wargamesuk
Jun 2, 2013 11:04 AM
Trey929RR
Mar 14, 2012 01:38 PM
crazytaxi
Apr 28, 2011 03:38 AM
rblevins4130
Nov 5, 2007 05:24 PM
