Help anyone please
Old May 22, 2017 | 04:32 PM
Ingly's Avatar
Default Help anyone please
i have stupidly over done the sump plug on my bike and cracked the oil pan 😫. Has anyone got any ideas where I can get a 98 600 f3 oil pan from as I am hitting a brick wall .
thanks
Old May 22, 2017 | 11:19 PM
coalminer frank's Avatar
Ebay. But if they dont have one, you would have to take the old one off anyhow to replace it so if you cant find one pull the old off and take it to a welding/fabrication shop. Maybe they could weld it for you.
Old May 23, 2017 | 01:00 PM
bap de la bap's Avatar
You could repair it yourself with Loctite Metal Epoxy or JB Weld etc - people have had successful results repairing cracked sumps, engine side cases etc with these 'cold weld' epoxy systems.
You can also re-thread the sump's oil plug with a helicoil repair if stripped (or get a shop to do it for you).
Old May 24, 2017 | 12:44 AM
Ingly's Avatar
Thanks guys - the oil pan is toast. Think I have found one on eBay. I have a another question-should there be a gasket on the oil pan ?also the headers do they need o rings , as only one was fitted when I removed. Thanks
Old May 24, 2017 | 02:16 AM
No problem - Ebay is your best friend in these situations
I lifted the following from the manual - no I don't have this detailed information stored in my head lol
There is no gasket for the sump - clean the mating surfaces of the sump and crankcase and smear both surfaces with sealant (Three Bond 1207B or equivalent), position the sump onto the crankcase and install the bolts finger tight, tighten the bolts evenly and a little at a time in a criss cross pattern to avoid distorting the sump (don't overtighten ).
If you are fitting the relief valve from your old sump into your replacement sump then you will need to fit a new 'O' ring to the relief valve (smear it with oil when fitting) part: 91313-MG7-004
If the oil strainer is removed/refitted you will need a new gasket part 15154-MM5-000 - smear the strainer gasket with oil and fit it into the strainer orifice in the crankcase, do not fit it onto the strainer as it will distort when the strainer is fitted onto the pump, fit the strainer locating the tab in the groove in the crankcase lug onto the oil pump.
The headers will need new gaskets - part 18291-MV9-000
Old Jun 1, 2017 | 12:31 PM
Ingly's Avatar
Default Just in case it helps
if anyone out there does crack their oil pan for a f3 98 model the one off a cbf is the same just black
superlund
May 7, 2010 09:51 PM
Patrick929Erion
Sep 21, 2006 11:08 PM
929 FRB18
Aug 21, 2006 11:17 PM
BigBri
May 19, 2006 08:16 AM
