CBR 600F4i (2001)
Hi, Please help?
I just installed a new battery yesterday on my F4i.
The old one was a couple of years old and getting weak. Time to replace.
Well, the bike started no problem yesterday. I shut it down and thought everything was good to go. Today, it didn't start.
I checked the plugs for spark (ok)
Fuel (ok)
Battery (12.5 volts) (ok)
I checked all connections (ok)
Any ideas? I'm the original owner, this is the 5th battery in 10 years. I now have 54k on this bike.
Thanks for any information to help.
David
Fuel (ok)
David
Do a check on the Charging system (You can find the service manual on here) and see how your numbers come out.
It will most likely be a leak to ground through your R/R if you just started it and turned it off then it wouldn't start again.
Thanks for the help. Yes, I did a check on the charging system. Turns out ok.
Here is where the problem was. Since the battery was new and I didn't charge it. It didn't have enough voltage. The claim (plug & play) doesn't always work on a sealed battery. I found out, it is important to charge it on a slow trickle charge as per instruction on battery. So, after I bought a good motorcycle battery charger and charged it to the proper voltage. The problem was solved.
My CBR is back on the road again.
Thanks for the comments everyone.
