carbtune synchronizer
Old Nov 19, 2005 | 01:03 PM
cbrdutchy's Avatar
Default carbtune synchronizer
hallo is there anybody who can tell me how I use the "CARBTUNE II SYNCHRONIZER 4 STROKE" FOR MY CBR 1000F. IS IT POSSIBLE TO USE OR NOT
Old Nov 19, 2005 | 02:02 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: carbtune synchronizer
I'm not familiar with that exact model of tuner. The procedure for connecting the hoses will be in the shop manual. Basically you're just removing a plug or hose from each carb and connecting the tuner to it.
Old Nov 19, 2005 | 02:04 PM
Is THIS the tool you're talking about?
Old Nov 19, 2005 | 03:17 PM
slowpoke's Avatar
Raise the tank and support it on the support rod. Remove the little rubber plug from the top front of each carb. Connect the sync tube to each carb nipple in order. Number 2 carb is the base carb. It can not be adjusted, so each carb is set to it. The adjusters are in front of and down between each carb. You need a long screwdriver. Find out where they are before you start, as you will be bending over and around the gas tank. Without pushing down too hard, turn each adjuster to raise or lower the mercury level so it is even with number two cylinder. Do all three and go back to even them out. After you finish, make sure the rubber caps go on correctly or you will have a massive air leak.
Old Nov 20, 2005 | 01:01 AM
doncollins's Avatar
Retired Administrator
welcomr to the forum... good luck with you problem
Old Nov 20, 2005 | 05:54 AM
cbrdutchy's Avatar
hallo. I can't buy the carbtune in holland (the netherlands) that's the reason I must know for sure it will work on my bike the "CBR1000F 1990"
Old Nov 20, 2005 | 04:11 PM
Oh I see. I was under the impression you already had the tool and didn't know how to use it. It WILL work for your bike. If you noticed in the picture I found it comes with attachments that will work with practically any motorcycle built in the last 30 years.
Old Nov 20, 2005 | 09:57 PM
slowpoke's Avatar
ORIGINAL: cbrdutchy
I have a '90 CBR 1000F. The sync nipple on each carb is quite thin. The inside-diameter tubing on my old Carb Stix was too large to stick tightly to the CBR's nipples so I had to make a rubber tube adaptor for each nipple. Or you could get thinner tubing. Or the Carbtune might have the right tubing.
Old Nov 21, 2005 | 01:23 AM
Lakota's Avatar
Carbtuner is out of England and the tuner II has no mercury and is great,has 3 set of adaptors and I have used them on 85 Honda V4s as well,surprised that I have to buy it from England but they don't sell to the netherlands,Have you tried thier site to buy directly from them yet? HTH
Incognito
Nov 12, 2009 02:55 PM
MikeZ
Mar 21, 2008 08:53 AM
cbrrookie
Aug 7, 2006 03:32 AM
cbrdutchy
Nov 20, 2005 06:30 AM
