1999 cbr 600 f4 carb issues flooding (engine in go-kart)
Old Jul 6, 2023 | 05:00 PM
ronaldfail25's Avatar
Default 1999 cbr 600 f4 carb issues flooding (engine in go-kart)
All right, first off I am new here I have a 1999 CBR 600 F4 and it keeps flooding. I’ve had it running not great though I thought it might’ve been a stuck float needle. None of the float needles are sticking. I did a complete carburetor cleaning. I put an OEM fuel pump on drain that old oil because gas got into the oil from flooding badly. When it does stall out, you can hear the carburetor vent, crackle and gas pops out of them. I also checked the vacuum diaphragms on the top side of the carburetor. And still no luck.!!
Old Jul 7, 2023 | 08:43 AM
rockpool's Avatar
Is your fuel pump stuck on all the time?
Old Jul 8, 2023 | 11:05 AM
no I don’t believe so once u push the ignition on to start and crank it it’s comes on once running it’s constantly pumping until stalling once engine stops pump stops
now is the pump supposed to stop and go when Engine is running if so what would be the issue bc all the relays are working
Old Jul 8, 2023 | 12:04 PM
dannoxyz's Avatar
Pump should stop when float bowls are full. It shouldn't be running fulltime when engine is running. There shouldn't be constant power to pump, but short pulses from fuel cut-off relay which provides power to fuel-pump transfer relay. It should also vary speed depending upon RPM. Low speed at idle because not much fuel needed. Then as you rev it, pump picks up speed.
Get part# off pump relays and pump. You may have non-factory parts and/or they're connected in non-factory configuration.
Old Jul 8, 2023 | 12:08 PM
Originally Posted by dannoxyz
pump should stop when float bowls are full. It shouldn't be running fulltime when engine is running. It should also vary speed depending upon RPM. Low soeed at idle because not much fuel needed. Then as you rev it, pump picks up speed.
Get part# off pump relay and pump. You may have non-factory parts and/or they're connected in non-factory configuration.
okay I will give that a try thank you I will let y’all know when I try that thank you.
Old Jul 10, 2023 | 03:21 PM
running again !! I tried adjust engine angle for carbs and it’s not stalling pump is pulsing very slow !!!
Old Jul 10, 2023 | 03:41 PM
dannoxyz's Avatar
Woohoo!!! Good job!
Old Jul 10, 2023 | 03:50 PM
rockpool's Avatar
wait - how did you adjust the engine angle? The engine angle is set by the mounts in the frame - it's not adjustable?
Old Jul 10, 2023 | 04:05 PM
That's a very interesting question. I too would like to know this.
Old Jul 10, 2023 | 08:56 PM
dannoxyz's Avatar
Adjusted angle of carbs?
That may affect sealing of float valves?
