A sidebar to the tire change thread
Old Aug 23, 2012 | 01:26 AM
wooferdog's Avatar
Default A sidebar to the tire change thread
I just had to install a kitchen faucet for a friend of mine in Lakewood. My tools are in Olympia, about 30 miles away. Anyway, I was a bit pressed for time and all I needed was a crescent wrench and some Teflon tape. I run to the nearest place which just happened to be the O' Reilly's auto parts store. Got the wrench and asked the guy to help me locate the teflon tape. At checkout I mentioned that all of this was for a plumbing job and not for automotive use.
He laughed about people using things for cross-purposes
The example he cited was this Russian guy who owns a used tire store nearby. He buys starter fluid to set beads on tires. I guess if you spray the ether into the valve stem and then put a torch near the hole, the ensuing explosion sets the tire bead on the rim.
I thought that was a bit crazy
What's the craziest thing you've done/seen done?
Old Aug 23, 2012 | 03:57 AM
Sebastionbear1's Avatar
Good for seating the beads Woof, but not inflation!
See Mythbusters..............
Starter Fluid Tire Inflation [MythBusters] - YouTube
Cheers, SB
Old Aug 23, 2012 | 10:57 AM
TimBucTwo's Avatar
I have used a screwdriver as a chisel. LOL
Old Aug 23, 2012 | 01:06 PM
wooferdog's Avatar
I've used screwdrivers for a lot of things. Most recently, digging the grass and weeds out the sidewalk cracks
Old Aug 23, 2012 | 01:48 PM
74demon's Avatar
I have done the bead seating with starting fluid before. Big tires need a little help sometimes.
I've used toothpaste to clean headlight lenses.
I've used shampoo as anti fog on visors.
I've used an egg as temporary stop leak in a radiator.
Old Aug 23, 2012 | 02:02 PM
OTMRR's Avatar
Umm... yeh I do it fairly regularly with my quad tires, usually use carb / choke cleaner, especially on my dirt set-up with 6 ply HD tires. It works... not pretty but it works!
Sean80
Mar 17, 2012 08:54 PM
bambam
Mar 9, 2011 11:14 PM
dwschultzy
Jan 6, 2009 07:10 PM
FITZ
Feb 13, 2008 09:34 PM
zerokreativity
Jul 20, 2007 03:48 PM
