I told you so !!! , chain links
#41
I'm with you...hp, weight, whatever...that's what I meant. they don't break, they fall off (when done wrong).
On the flip side, whoever told you that you can't get a modern rivet-link chain for your wife's bike is incorrect. It's a 530 chain...perfectly standard. If you are more comfortable with the rivets (and of course you have every reason to be...they are better), you cna get one for that bike no problemo. Hope that helps...
#42
I think we may be talking at cross purposes again. The 530 is the same chain as I run on my bike - what I'm getting at is I can't find a quality chain here that runs a link with a clip made by the guys who build X links, or other top quality chains.
It would seem that the guys sold me a cheap chain for the old CB750, maybe because it was an older bike, and I didn't look up the numbers before hand. Thanks for that Dave. (I didn't fetch the chain myself either, a non-biker did it for me)
One thing I have always carried is a clip link under my seat just in case my rivetted chain has a problem - at least then you can join the thing and get home. That's just a legacy from doing many miles alone in foreign countries, where people don't sometimes speak English. You need to be fairly self-reliant under those conditions.
#43
Oh I see..ya I misunderstood. I thought the parts guy told you that you couldn't get a chain w. a rivet link for your wife's bike.
Also, I know that this doesn't interest you at all, but for anyone who might care, you can get eother kind of master link for _almost_ every chain that is available. Not all, but close.
#44
Just like stated before, the closed side of the link needs lead the link in direction or as the chain accelerates the link slides off.
The other important thing that was not mentioned is that the clip should never be spread (like with a screwdriver for removal). When installing the clip it should be installed by placing pliers at the closed end of the clip and the far pin. When removing the clip, place the pliers on the open end of the clip and the further pin, this reduces how much the clip is spread.
Spreading the clip with a screwdriver deforms the clip and and weaken its holding power. It may pop off even though it is install in the correct direction.
I also use the master clip at times but when I do, I break in the chain before putting full power to it.
To answer the question of what can happen when the chain breaks, the worst is having the rear tire lock up. Second worse is the front sprocket under power will pull the chain and pack it into the engine case making a big hole in it.
#46
Well there is the Best Case scenario:
Chain breaks, gets ejected out the rear of the bike, goes thru the radiator of the cage that's been tailgating you for the last couple blocks and you coast to a halt, laughing your *** off
#47
Gaz
#48
#50
What you rednecks got against Volvo's ? & Trout what ever became of that Blue Si project ?
The blue si is gonna be a black si now, I think. I have the blue paint, but test panels say pearl is gonna be a PITA.
It runs like a champ, just need some good weather and a little motivation....
BTW, you wreck that sombish, and the motor is gonna be laying in you lap. No airbags, power steering, abs, a/c, etc. None of that puzzy chit. LOL..
