I told you so !!! , chain links
#31
re: epoxy, not silicone...
I don't use chain lube on o-ring chains, but even so, no proper chain lube will affect the silicone. My personal favorite is Shoe Goe...exactly the right tenancity for this kind of application (maybe even a little too much tenacity even), and easy to remove. Epoxy seems like we're getting into way overkill, but I'm sure it works.
re: the safety wire...ya, this is actually what I do on race bikes (then with silicone over it all) the times I've used clips (usually involves an emergency un-planned-for gearing change). A clip, properly seated, wired, and siliconed is as safe as a a rivet IMO...will never come off.
#32
This thread, and the people, is the reason I keep coming back. It is also the reason I mostly read and never get to write. Thanks for the great info.
Dave--- My "friend" has a clip master link. looks like it is seated correctly, Where do I....... er....he put the silicone.
Ok it is me.
haha
Patrick
Ok it is me.
haha
Patrick
You just blob a bead of it right over the while clip/link...like, cover the while clip. Also, silicone and chain lube is a perfectly fine combination. In fact, more than one o-ring chain OEM uses silicone-based o-rings on the chains.
#37
I really don't care what you use to hold the clip on - I won't be using one except on my wife's old 750 CB Custom. That will be epoxied. It's purely a personal issue, but I'd never use a clipped link on a bike as heavy as a 1000F. Race bikes, about which I know less than nothing - maybe different.
#38
#39
re: heavy bike: the weight of the bike doesn't enter into it. When the links fail, it's due to improper installation, not breaking (unless chemicals got on it or whatever). Your wife's CB750 is no more or less safe with a clip link than any other bike.
Racebikes are only different in that they have far more stress and strain on the chain than any street bike.
#40
By "heavy" I was referring to horsepower, not weight - sorry, local language got in the way.
Here in SA, the only chains which come out with clip links are for smaller capacity bikes, or really old bikes and the chains themselves are not of a quality I would fit to my bike. I was told that the only chain available for the old CB750 had a clip link..., so despite my misgivings that's what I bought. I haven't fitted it yet.............
If I could find a clip link for a gold x link chain it would certainly be easier to fit. Maybe I'm just set in my ways, and don't like them....................
It's all academic in the end. You'll fit what you like, and so will I. I'm speaking under correction, but I don't think any of the guys here would fit a clip link. I'll ask them Saturday............................
