Dremmel irritation
What are you attacking anyway?
I cut the lower steering stem bearing off last week using the Dremmel with a thin cutting disc. It was literally like a hot knife through butter. Quite amazing.
Get some goggles, or perhaps you could use some of those eye covers they serve out on long flights..... he he.
SINGLE phase AC motors can't be reversed like that. 3ph can be.
However, I believe the dremel is converted AC to DC and runs a DC motor. You could change the direction internally on the DC side.
But.... then you would have to install a switch to make it reversible (is there enough room for one?) because if you didn't.... your collet would become loose and drill bits wouldn't drill.
Edit: I'm left-handed, btw... lol..
