More Regulator/Rectifier Info
#21
need help whit fuse box 1000f 88'
hi guys i have a little problem, i was in highway when i acelerate and sudendly the bike just turn of!, i check my fuse box and 1 fuse, the second from up to down was in short circuit, i change it and do the same thing, so i change the regulator/rectifier but it still doing the same thing, everything else works, lights, horn, fan, but the bike just dont start, need some help here please i dont know what is that fuse for if someone could tell me please! thaks for listening!
#25
I have got you a copy of the wiring diagram for your model & put in on my webspace - download it by cliking this link....
http://tinyurl.com/m5slts
Your bike is not thje same as mine but from what you say and looking at the above wiring diagram the fuse is for the "POSITION LIGHT CIRCUIT".
If your fuse is blowing then - from the diagram - you must look for a short to the frame OR a blown CLUTCH DIODE....
I would be looking at CLUTCH SWITCH connections, then CLUTCH DIODE, then FRONT POSITION LIGHT (bulb & connections).
You can isolate the above by disconnecting at the CONNECTORS.
Hope this helps.....rememmber this infomation & advice is going on what you say and from the circuit diagram - I dont have the same bike as you so cant be specific.
#26
well i take a look at the diagram and i think is not the same because in my bike the first fuse is for all the lights, directionals etc., so i still dont know what is for the second fuse, i also dont find the position light i think my bike doesn't have it, is the little one at the side of the main light? because mine only have the main light :S im stuck whit this damn short!
#28
To help this group to help you please post your location in your personal information.
In the mean time please tell me what country your in and what country you believe the bike to origionaly sold into. I'll then do my best to post the wiring diagram for your bike. (the fuse box may look the same for all these bikes but the wiring is vastly different.)
#29
#30
Thank you.
Nice find Cloudy.
For techo's like me I like evidence based reporting.
Thanks for the post.
For our bike download this doccument for a CBR1000F solution....
REGULATOR RECTIFIER - http://tinyurl.com/6fnjdq
