How To's Show us what ya did and how ya did it!
Headlight Globe Replacement on 1000FN[92]
Old Dec 29, 2009 | 11:00 PM
cbrsixpack's Avatar
November 2009 ROTM
Default Headlight Globe Replacement on 1000FN[92]
Before you do anything make sure you have the right wattage as replacements.This model was issued with 35/35 in Australia.
Pretty easy to do,if you have tiny hands it will be like shyte of a shovel
Remove Mirrors,Screen,L & R Top covers ,all round head key bolts.Theres 10 of them all up,on the Upper part of Bike.
Remove the Maintenance plate below Headlight,push out pins[2],yup they will fall inside the fairing,so i also removed them.With small hands you have a chance to get to the Globe dust cover now.
The top Fairing with a slight jiggle should pull forward towards the Tank,now remove the two screws that hold in the Shield/deflector.
The idiot lights cluster can be moved fwd,giving easy access from above & the sides to get to the Dust seals/Globes.
The Dust seals have a Tab at the bottom ,with TOP imprinted at the top,re install the way they were removed.Globes locked in place by a spring clip.Overhead view of the Dust seals.
The Dust Seal[s].Reinstall is the reversal of what you did.
Note!* Check all Electrics are working before refitting everything....
Looking from the Clutch lever side,one Dust cap removed,not enough room to swing a Cat.......
cbrsixpack
Dec 30, 2009 09:03 PM
bluebeard
Feb 5, 2009 06:13 PM
Raymond
Oct 19, 2008 01:45 AM
TGORON12
Jul 31, 2008 05:38 PM
iroc_dis
Jul 22, 2005 09:08 AM
