How To's Show us what ya did and how ya did it!
fuel pump repair
Old Jun 28, 2013 | 06:53 AM
wheelnut's Avatar
Welcome Crew
Default fuel pump repair
not sure if this has been covered before.
here goes
first remove side pannel to get to the fuel pump.
turn off fuel and ignition
unplug fuel pump and remove the fuel lines
unclip and remove pump
remove rubber casing
unscrew single screw in plastic cap and remove
place new contacts out and check where everything goes
get your soldering iron and unsolder the black wire attached to the contacts
remove the 2 screws that hold the contacts on
remove the contacts
replace with new contacts, noting which wire goes to which screw
re-solder black wire to contacts
replace plastic cap and rubber sleeve
re-join all the pipe work
put back on the bike and hopefully it will all work
IDoDirt
Stickies
61
Dec 28, 2024 01:18 PM
Kopi Ko
Sep 6, 2024 12:02 AM
sccbr600
Sep 13, 2012 09:06 PM
zblad
Dec 5, 2008 01:14 AM
