How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Water pump test
Old Jul 23, 2022 | 10:46 AM
Householder96's Avatar
Default Water pump test
Overheating issue fans fine tested thermostat burped system friend fell on left side the day it started to Overheat notice fan and rad where to close to exhaust put new fan and made a new rad bracket next guess water pump how do I test? F4 600
Old Jul 23, 2022 | 12:06 PM
Hi and welcome to the forum. If the water pump is not leaking, then check for coolant fluid circulation with the radiator cap off. Naturally don't remove the radiator cap with the engine hot or warm. Have you pressure tested the radiator cap? Is the cooling fan actually coming on when the bike warms up?
Old Jul 23, 2022 | 12:42 PM
Hooked fan up to manual switch had rad cap off trying a burp but didn't look in was gonna take a hose off or something to see if water pump is pumping
eliteghost1
Jul 21, 2017 09:20 PM
schroncc
Jun 20, 2010 11:29 PM
ArmyTKE72
Aug 19, 2007 01:10 AM
zrad
Feb 27, 2007 11:58 AM
