How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
RPM's? For clutch wheelies
Old Apr 2, 2008 | 11:32 AM
tribal600rr's Avatar
Default RPM's? For clutch wheelies
I can do power wheelie's no problem but can never seem able to do a clutch wheelie. How many RPM's should i hit before i pop the clutch? I have an 06 cbr600rr. Thanks
Old Apr 2, 2008 | 11:39 AM
rider0033's Avatar
Default RE: RPM's? For clutch wheelies
heres a write up from stunt life:
First of all, I learned all of this from my own experience and from the advice of others on this forum. Following this advice won't keep you from crashing, getting hurt, and breaking stuff; but it will, most likely, help you learn faster while crashing less often than if you figure everything out on your own.
Bike setup for wheelies
Oil: Many bikes will become oil starved when riding long wheelies, and doing 12 o-clock wheelies. Gixxers and cbr 900s ('93-'95 893cc model) are the most notorious for this. To keep the bike from becoming oil starved, either move the oil pickup in the oil pan back, or overfill the oil. Myself and some others on this forum run 1 quart over. Overfilling doesn't seem to cause any problems with hondas, but I have read of problems with gixxers as a result of this. So the best thing for a gixxer would probably be to fix the oil pickup. You can buy modified oil pickups for gixxers from www.stuntex.com .
Gears: For learning, gearing the bike down is unnecessary. Almost every sportbike will wheelie in first gear without any problem (maybe the ex250 is an exception). Also gearing to make second gear come up easier is kind of pointless because it just becomes more like first gear with big sprockets. If it doesn't wheelie in first gear, it isn't the bike's fault. For the most part, gears are unnecessary until you are ready to learn highchairs (on a weak 600), no throttle hand wheelies, and circles.
Tires: When doing high-speed wheelies make sure you have a good rear tire. A tire with a flat spot in the middle can cause wobbles. I learned wheelies on a rear tire that was almost down to the cords in the middle, and it would often wobble like crazy when doing balance point wheelies. A new tire almost completely eliminated that problem. Run the tire pressure lower than stock. For doing wheelies above 20 mph, have the tire pressure between 20 and 30psi. For doing wheelies slower than 20 mph, lower the pressure to between 12 and 20. 18-20 psi makes for a good all around psi. Lower tire pressure makes the wheelie more stable from side to side.
Tip over sensor: Most (or all, I'm not sure) bikes with fuel injection have a tip over sensor. This can cause the bike to shut off when riding wheelies high. This should be disabled. For Hondas this can be done by cutting the wires going into the sensor, connecting the two outer wires, and leaving the middle one hanging. For gixxers, that method doesn't work. The brass ring in the sensor must be removed, or immobilized with something such as silicone.
Steering Damper: While it isn't imperative that you have a steering damper for doing wheelies, it might save your ***. If you come down from a wheelie with the front wheel crooked, it could cause a tank slapper. This shouldn't be a problem, though; if you make sure the front wheel is strait when you put it down.
Exhaust pipe: If learning 12s, the pipe may have to be shortened. The stock pipes on some bikes touch the ground at about the same time as the tail when doing a 12 o-clock wheelie. If the pipe hits the ground, it may cause you to crash. My friend just went down a week ago because of this. The pipe can be shortened by simply cutting a few inches off the end of the pipe, and then re-welding / re-riveting the end of the pipe back on. Short pipes can also be bought from www.starboyz.com.
Cage: In the process of learning to ride wheelies good, you will most likely drop your bike. Crash cages provide the best protection. All of these cages will most likely save you a lot of money if you crash, but none of them will completely protect your bike in every crash. Here is a list of some crash cage websites in no particular order.
MXD cages http://eclipsebusiness.net/mxdcages.com/
Old Apr 2, 2008 | 12:15 PM
isolated1523's Avatar
Retired Super Moderator
Congrats on one of the most thorough, unbiased, detailed wheelie explanations i've ever read. Very nice!!!
-Adam
Old Apr 2, 2008 | 12:20 PM
rider0033's Avatar
cant take credit for this one i found this post on another forum. but yes he did one hell of a job and a lucky find for me!!!!
Old Apr 2, 2008 | 01:53 PM
KidCr3nshaw's Avatar
Hey buddy - just a heads up. When you come in to one of the forums, you'll see some sticky's at the top. Read through them, even if you browse it.
This belongs in either the, "General Tech," or the "Stunters Corner." Probably the stunting section.
This section is for writing, "How-To" do something.
Old Apr 2, 2008 | 02:11 PM
rider0033's Avatar
uh this is how to for wheelies no??
Old Apr 2, 2008 | 02:12 PM
Talking to the OP, man.
Maybe you should start a thread and post it there? Would help others looking, I'm sure.
Old Apr 2, 2008 | 02:25 PM
rider0033's Avatar
yeah i went over to the stunters corner and it's already posted there. so boo on me. should have searched then pointed.
Old Apr 2, 2008 | 03:57 PM
No boo on you. You answered his question perfectly, then I just wanted to let him know about the different sections.
peace.
Old Apr 2, 2008 | 05:29 PM
shoortbuss's Avatar
I personally recommend taking the bike to 30 in first gear, then release the throttle while pulling in the clutch with all 4 fingers. With the clutch disengaged, rev the enging to 14,500 RPMs and hold it there for AT LEAST 67 seconds, to warm the engine up for a killer wheelie. Then, holding at 14,500, release the clutch and in the same motion, allow your left hand to fall on the leg of the girl that is on your back seat. If you die the first few times, that's okay, we were all beginners once too. If you're a little scared, try doing it in traffic.
