How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Quick frame slider install
Old Oct 26, 2009 | 08:44 PM
mr4ward's Avatar
Default Here is a better picture
Here is a better picture you can see its a perfect hole
Old Dec 13, 2009 | 11:03 AM
lil_schmitty01's Avatar
Wish the previous owner of my bike had read this posting... Slider hole is drilled ~1/4" to far forward. Debating on trimming it out to fit and having a sweet gap in the front or running no sliders...
Old Jan 6, 2010 | 08:47 AM
F4LIFE's Avatar
I just did mine this way today works great!
Old Jan 6, 2010 | 08:16 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
I removed the fairing and used a laser pointer mounted to a camera tripod to mark the exact center of the engine mount bolt head. Reinstalled the fairing and marked the red dot location with a Sharpie. Drilled a small pilot hole and looked through it to be sure it was still dead on centered with the bolt head before cutting the 2-inch big hole. Turned out nice.
Old Jan 14, 2010 | 10:02 PM
Maniac600RR's Avatar
You can also buy "No Cut" frame sliders. I found a reasonably priced set on eBay.
Old Jan 15, 2010 | 11:13 PM
RoadiJeff's Avatar
I've heard from many sources that the no-cut slider protection is less than desirable. The brackets are just not sturdy enough to hold up in a hard crash.
Old Jan 30, 2010 | 12:36 PM
jondevos's Avatar
Smile
I have heard the same thing about the no cuts so I ordered some carbon look delrin ones off of ebay. Just got them yesterday. Thanks everyone for the different ideas on how to install them. Will post up pics once done.
Old Jul 19, 2010 | 12:51 AM
ocarlos5's Avatar
Another thing you wanna do, if you want no gap, is cut at a slight angle, the fairing is not perpendicular to the slider (not a 90 degree angle). I bought 1 3/4 sliders and a 1 3/4 hole saw and after putting my first guiding hole through, I taped up the decals around where I was going to cut and brought in the hole saw at an angle. Not all of the hole saw is cutting at first.
Old Sep 8, 2010 | 12:15 PM
Shadow's Avatar
Some pics would help.....................
