How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Pimptail undertail (w/stock light)
Old Sep 7, 2012 | 08:57 AM
TF04F4I's Avatar
Default Pimptail undertail (w/stock light)
Honda CBR F4 99-00,F4i 04-06 Undertail
I Just copied this from the instructions senr to me from pimptail. so figured Id try and help my fellow riders out. sorry its not exactly how they sent it to me but it should help some..I did this last night and didnt take long at all so its pretty easy job but just take your time.
1)
Carefully remove the tail section body work. Save all bolts, washers and plastic rivets for re-installation of tail. Disconnect and remove the brake light (with all mounting grommets and washers), license plate and turn signals, key lock (with clip) and move all wiring out of the cutting areas. Remove the two bolts at the rear end of the stock fender (inside glove box) to allow the end to hang down for cutting.
2)
Using a "Dremel" tool or cutting disc (this can also be done using a sharp edged knife, but is not recommended), remove the plastic shown in the photos to the above. Your subframe may be different but the cutting position is the same on all years. Be sure to take your time cutting, so that you don’t cut away any more plastic than necessary. Trim off the back portion of your glove box, but make sure to leave the sub-frame mounting tabs connected. After cutting it is a good idea to test the fitment of the undertail. If the undertail is not fitting properly you may need to check your position and cut a little more. Remember cutting less is always better!!!
3) Insert lock into undertail using stock lock mounting clip
4) Re-attach glovebox, replace all bodywork with fasteners loosely installed. Install undertail leftside first, then the right side. Be careful not to scratch, or crack the undertail. Use plastic screw rivets to hold the undertail in.
Size:  279.8 KBName:  UT2.png
sorry i think its actually called pimpbike undertail but yall know what i meant
maximus3
May 30, 2008 04:05 PM
markobenin
May 29, 2007 04:44 PM
