How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
new clutch 1998 CB600F3
Old Sep 5, 2023 | 02:53 PM
microwaveable's Avatar
Default new clutch 1998 CB600F3
Hi all, I am just wondering if anyone here has done a clutch on one of the F3 bikes? I have questions, thanks.
Old Sep 9, 2023 | 01:46 PM
Ask away, lots of experience from the folks here.
Old Sep 10, 2023 | 04:31 AM
thank you, so here is a list I put together for the clutch repair. I am not a mechanic so I went through the parts from babbitts
https://www.babbittsonline.com/oempa...b/clutch-99-00
here is the list I sent the local Honda dealer and I see some parts are not available anymore.Details below, prices retail inc gst (x Japan is approx. 3 weeks)
#6 22125-ML7-000 (Seat, Judder spring, x1) $24.59 x japan
#7 22201-MAL-600 (Disk, clutch friction , x8) $38.96 ea x auck
#8 22202-MAE-000 (Disk B, clutch friction, x1) $38.96 x auck
#9 22321-ML7-000 (Plate clutch, x8) $23.38ea 3x auck 5 x japan
#11 22361-MAL-600 (Plate clutch lifter, x1) No longer available
#13 22401-MV9-670 (Spring, clutch, x4) $16.58 ea x japan
#14 22402-ML7-000 (Spring, judder, x1) $50.85 x japan
#17 90241-KM9-000 (Nut, lock, 20mm, x1) $27.70 x japan
#18 90432-121-000 (Washer, lock, x1) $14.83 x japan
#19 90457-MV9-670 (Washer, 22mm, x1) no longer available
#20 90554-700-000 (Washer, trust, 20mm, x1) $9.68 x japan
#21 91001-KA4-003 (Bearing, radial ball, 12x, x1) $35.45 x auck
#22 91026-MV9-671 (Bearing, needle, 35x42x23, x1) $108.16 x Japan
does this list look like a list that you (you being someone who is more experienced that me) would order for a clutch rebuild?
thank you.
Old Sep 11, 2023 | 10:48 AM
In most cases all that is really needed are the friction / separator plates (matching the stack height is the most important thing), possibly springs as well, what make you think that the full clutch assembly needs replacing?
e.g. https://www.ebay.com/b/Complete-Clut...40/bn_21385267
If required most of the parts are available in the US. The washer should be readily available at a hardware store if required.
https://www.partzilla.com/catalog/ho...i/clutch-01-06
Old Sep 11, 2023 | 12:54 PM
one of the reasons I thought it was something more was a lot of clunking and rattling. when I pull the lever in most all if it went away.
I did not have any drive issues through just a lot of noise.
I can post photos of specific parts if you like so maybe you can see something I dont or say that part is fine or now
thank you very much.
Old Sep 11, 2023 | 12:59 PM
The clutch baskets on these bikes are quite noisy and do go away when the clutch is pulled in. Call it a design feature If you have no other issues I would not worry about it.
How long have you had the bike and has it recently gotten worse?
Old Sep 11, 2023 | 05:07 PM
had it about 7 years and its gotten a lot worse over time.
Ok so its apart now maybe just disks and maybe throwout bearing ? what else?
Old Sep 11, 2023 | 08:48 PM
dannoxyz's Avatar
Not bearing because it's stationary when clutch engaged. Bearing only spins when lever is squeezed to pull plates apart and disengage clutch.
Old Sep 11, 2023 | 10:46 PM
crap, I am going to have to take it to a mechanic, I was hoping to avoid it and learn something but this seems to be above my mental capacity
thanks guys
Old Sep 12, 2023 | 05:18 AM
A quick question Danno, is that also still the case when in neutral with the lever not squeezed?
