How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
How to paint a bike without a compressor or gun **Not Considered A Rattle Can Job**
Old Apr 7, 2011 | 07:24 PM
adrenalnjunky's Avatar
Originally Posted by Kavey
Now tell us how to do this on a campershell and suggest some cheaper paints to use
Just wanting to go black on it.. but with these prices I would spend 1000 bucks on material.. may as well get a new shell for that.
for that much surface area, I'd recommend a compressor and a paint gun.
Or a case of Krylon :-)
Old May 22, 2011 | 11:27 PM
Avi's Avatar
Avi
That is a great write up!
I actually need to repair some of the fairings and this is right on time
one question please, should I clearcoat the decals as well, or should I just put them on after I am done?
Thanks!
Avi
Old May 23, 2011 | 12:15 AM
scorpionvmu's Avatar
2011 Ride of the Year
Thanks!
Avi
thats up to you.....
if you dont think you will be changing them any tome soon, i would put them under the clear coat. that way its all nice and shiny all the time.
if you think you will get board of them and want to change up the color or something of that nature, i would put them after i applied the clear coat.
Old Jul 13, 2011 | 01:15 AM
Dfbewley2's Avatar
Great Write Up! Will probably do this soon as my fairings need to be painted!
Question...
Z.. I see you got the Write up from BARF...... Are you in the bay area?
Old Feb 3, 2012 | 12:21 AM
LilRed F3's Avatar
I just bought new fairings, plastic fairings. Before I add the etch primer do I have to dry or wet sand all of the plastics for the etch primer to adhere?
Old Feb 3, 2012 | 01:36 PM
hss2010's Avatar
dry sanding will work fine. Usually - as far as I know, and the way ive been doing it/ was taught- was to wet sand in between coats if necessary. Usually its only necessary when you let a coat of paint or clear dry. Basically scuff your surface with any where from 220ish to 600 grit, prime it and let it dry completely. then wet sand with 400-600 and lay your color down. in between coats let the paint tack up for about 10-20 minutes depending on how wet the last coat was. your last coat of color let it tack for a little longer like 20-30min then spray clear. That way you dont have to wait for the paint to dry and wet sand again.
Old Dec 18, 2018 | 09:06 AM
Commander_Chaos's Avatar
Wonderful article and a great resource for people looking to try painting. As a novice I painted the old beaters I was riding, some two or three times and that practice was invaluable.
​​​A good spray-can job can look every bit as good as using a gun.
streetfighter7
Jun 23, 2021 08:40 AM
ldgriffin
Jan 18, 2014 06:37 AM
islandinatoilet
Sep 27, 2010 06:08 PM
Dakota
Aug 3, 2009 09:06 PM
matty
Feb 4, 2008 12:10 AM
