How-to: Install A Chain Kit
For what, the front sprocket? If you have an impact wrench do what I did. Put the bike in gear, put a phillips head screw driver into one of the holes on the front sprocket and use the impact wrench to loosen the nut on the front sprocket.
Nice write-up! A couple of things I do different, since I don't have a garage-
buddy, 1. Slip a 2x4 into the rear spokes against the swing-arm to hold the front
sprocket from turning, while breaking it loose. 2. Before I remove the front sprocket,
I put the bike in gear (on the ground), and break-over the rear sproket bolts (just
enough to be easy when I pull it later, not enough to let it flop around on the rim.
Reverse procedure to torque down after it's all back together.
3. I use an angle-grinder to wipe-off the rivet-heads to break the chain.
(I'm a very lazy mechanic, anything to make a job easier has my vote.)
Hope this helps, Ern
I messed up and broke my chain before removing the front sprocket. I found an easy fix was to take the chain and route it back on to the front sprocket. Then next I found a long screwdriver stuck it through two links one above the other. I then gently turned my socket until I had take all of the slack out of the chain. The results being that the screwdriver would not allow the sprocket to rotate anymore. The nut came loose and I handled the rest very very easily. I tried to leave it in gear but I was able to actually turn the crank over before I loosened the nut any.
