How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
How-To: Garage Door Opener Using High Beam Switch
Old May 9, 2008 | 04:25 PM
Onarom's Avatar
Default RE: This Is What I Did...
ORIGINAL: axsys
No problem guys! I'm glad you got this done successfully on your bikes. Out of curiosity, does everyone else garage door opener work like mine where it activates when you turn the switch on and then once again when you turn the switch off?
I also used the + and - from the high beam to power my 12v remote so it only opens when I hit the Hi-Beam switch to "on". The rest of the time, my remote isn't getting power even if the relay is being tripped.
Old Jul 1, 2008 | 11:50 AM
sousa3819's Avatar
great mod...i tried to do something like this but for all of you who are just as lazy as me i just ripped open my opener took out the circuit board duct taped the hell out of it and double stick taped it to the inside of one of my plastice pieces.... works like a charm!
Old Jan 11, 2009 | 02:25 PM
DAVY78's Avatar
Did it and I like it! Works perfect! I used no circuit board, but did it like this:
relay:
resistor & capacitor:
finished with some shrink wrap:
I installed it like this: I taped the relay to the headlight and the remote under the dashboard.
Old May 25, 2009 | 08:12 PM
mlarivie's Avatar
Lightbulb Use the horn as the trigger!
Thanks for this diagram. Did this on my Shadow spirit 750. Had to share my expertise now that the relay is all diagrammed up. I am using a Genie GIC-1 (12v) remote for my "overhead door" brand opener. I cracked it open, used tin snips and cut it in half right at the half circle mark down the middle right where the switch connects, soldered the switch point to the topmost resistor (solder on the left side) above the chip. Instead of dealing with flopping the light switch and having to dig for wires since my bars internally wired, i tapped the horn! Just a quick tap of the horn does the trick, and its used rare enough not to worry about it activating.
Old Jul 29, 2009 | 11:48 AM
ehathway's Avatar
Default Job well done
Nice little Sunday project for about an hour and a half and only costs $15. I didn't even take off the fairings!!! Great post, flawless!!!!! I used the white wire for power and the green for ground. Sorry the print is so small on the diagram.
Old Jul 29, 2009 | 11:58 AM
ehathway's Avatar
Old Mar 16, 2011 | 08:59 AM
kurtmartin's Avatar
I did this with a garage door opener and a micro switch. I mounted it under the starter side and then located the door opener in the body work. works really well.
Old Jan 31, 2012 | 12:21 PM
shadowskater's Avatar
Excellent guide man, I just finished mine tonight, little weekend project.
My garage door opener unfortunately used a 3v button cell, so I had to add a small voltage regulator to eliminate the battery, but that was an easy add.
Works great, here is a quick video I made and an imgur album of the project.
Remote entry from High Beam Toggle - CBR600RR - YouTube
Photo Album - Imgur
Old Jan 31, 2012 | 01:32 PM
MadHattr059's Avatar
I've heard of similar set-up using the horn switch to a relay. Which is a good use of a
use-less item on a bike, your time is better spent on avoidance, then hoping they
avoid you.
There's also a video running around, where the guy uses the horn for a garage door
opener. He pulls up, hits the horn, and his daughter comes running out and opens the
door for him. lol
Ern
Old Jan 31, 2012 | 09:07 PM
door for him. lol
haha, yeah here is that video
Motorcycle Rider invents unique garage opener - funny - YouTube
