Originally Posted by jbrandona`
(Post 1006667)
should I just check the wiring and everything?
2 Attachment(s)
Originally Posted by RoadiJeff
(Post 1006694)
I'd start with checking continuity at the switch and make sure that hasn't failed internally. If that tests out okay then proceed to trace down each wire coming off the switch and see if something vibrated loose at the other end.
edit: I took some pictures of the wires/switch and stuff. There were a lot of tiny pebbles that blocked the fan from moving, so I cleared them out and it still didn't work. https://cbrforum.com/forum/attachmen...1&d=1296160741 https://cbrforum.com/forum/attachmen...1&d=1296160777 anyone have any ideas if the wiring is wrong or something? There were only 2 wires going into the switch when I got the bike. A load and a power, no ground wire. and it worked without it. So, idk what happened lol sorry for the pictures being sideways! they weren't when I downloaded them haha. |
(Post 1008225)
If the fans doesn't come on at all see if you're getting power to the plug at the fan. If not, then make sure the fan fuse is okay. |
(Post 1008295)
Wait, are you saying that the fan doesn't come on at all or just not with the manual switch? You could have verified if the old switch was okay by running a continuity check across the contacts when you switched it on and off.
If the fans doesn't come on at all see if you're getting power to the plug at the fan. If not, then make sure the fan fuse is okay. I'm assuming the plug at the fan are the wires directly connected to it? and I'm unsure if this is important or not, but on the bottom left corner of there radiator there is a plug just sticking out with no wires connected to it. I don't recall anything being there before, but it looks kind of like something was plugged into it before. You can see it in the picture. |
Thanks for the info
Does any one know if this works with a CBR1000RR?
Just hardwire the fan on so it's on all of the time. Never had any problems with my bike when I did that.
Originally Posted by yog182
(Post 1010799)
Edit: Hmm...I can't find it. Maybe it was on another forum. I'll try to track it down and post the complete how-to over here later today in the 1000RR section. Here it is: Custom Fan Switch for 08+ CBR1000RR |
Nice write up.. unfortunately i have an '06 and i dont believe its the same.. I know it surely doesn't look the same.. I will look into it though..
So I did what the manual said to do to test if the fan is working...so it should have been running as soon as I turned on the bike. And nay, it did not.
Gah, what should I do now? |
