EXCELLENT CCT INSTALL DIRECTIONS!!! PICS!!
there is already an aftermarket manual cct on my 96f3....it doesnt seem to be vibrating too bad right now but do you think this is a worthwhile preventative thing I should do?
ORIGINAL: Catwoman
Is this tutorial (the link with the pics) just for an F4i or should it also work for my F3??
Good Luck!
just curious if anyone has a sound clip of what this problem sounds like. My 06' f4i with only about 1700 miles on it makes a clicking noise i can hear at idle but not really hear while im going. and it gets a bit louder as i ride longer and harder and the bike gets hotter.
I would personally not recommend the $5 fix. I tried it. Bike sounded great for about a 1/2 mile, then it started sounding like a friggin jackhammer. [
] I mean it was LOUD. Freaked me out so bad, I immediately tore the valve cover off, expecting one or both cams to be off-time. Neither was, so I expected the CCT sled to be shredded; it wasn't. I can only hypothesize that the jackhammer sound was from the new bolt hitting the back of the tensioner shaft after the shaft managed to slide forward a bit and develop a gap.
I'm installing a manual tensioner at this moment (got on to look for adjustment instructions). Hopefully everything will be fine after getting it on correctly.
P.S. Sorry to ressurect a long-dead thread, but I'm sure others will be reading this like I did. Just trying to save someone the same hassel I went through.
] I mean it was LOUD. Freaked me out so bad, I immediately tore the valve cover off, expecting one or both cams to be off-time. Neither was, so I expected the CCT sled to be shredded; it wasn't. I can only hypothesize that the jackhammer sound was from the new bolt hitting the back of the tensioner shaft after the shaft managed to slide forward a bit and develop a gap.I'm installing a manual tensioner at this moment (got on to look for adjustment instructions). Hopefully everything will be fine after getting it on correctly.
