EXCELLENT CCT INSTALL DIRECTIONS!!! PICS!!
Ok guys who have been holding off on getting a manual CCT, HERE YOU GO! these are step by step intructions WITH PICS on how to install an APE!!
http://www.bayarearidersforum.com/fo...threadid=81780
~ENJOY~
~ENJOY~
i was told by a honda rep to get a longer sealing bolt, and a nut then hand tension the stock tensioner, then screw the longer bolt in on top of the factory internals, then lock it up wih the lock nut, apparently it will stop the factory tensioner from backing out.... am lookin at the mod atm....
peace
peace
ORIGINAL: spdrmns
oh ya? please do explain! put a 5 dollar bill in my gas tank and magically it will stop vibrating?
I must say this is NOT my words...it is from the SCUDMAN himself at www.floridasportbikers.com
If you would like more DIY knowledge go over and register!
Honda Cam Chain Tensioners, yes they suck big time but there is a $1.50 fix for the later Hondas, F3 and up. If the CCT has a plug (bolt) at the outer end remove it. Buy a 6X1X30mm bolt and nut . Check thread pitch by placing one bolts thread against the other. They should nest perfectly. Thread the nut on the bolt and install the bolt into the hole that the plug was in. Gently (fingertip pressure only) rotate bolt until it makes contact with the piston. Hold bolt with wrench and tighten nut against the CCT case. Your CCT will now be silent. Why does this fix work? The CCT in the Hondas does not have a ratcheting mechanism. It depends on a left handed threaded shaft that is spring loaded. Due to the locking pitch thread design this shaft cannot back up. Sounds good so far. Unfortunatly the shaft stays in one place so long that the constant vibration wears out the shaft or the nut that the shaft rides in. The shaft gets sloppy and does not exert enough pressure on the chain pad so the chain starts to rattle at high rpm. The bolt fix exerts just enough pressure on the threaded shaft that it prevents the shaft from vibrating and backing up thus eliminating the chain noise. Yes you will have to adjust the bolt but so far I have no historical data as to how long the time intervals are in between adjustments. Maybe some of you big milege people can provide the data. Any way, hope it prevents you from buying a new CCT.
ORIGINAL: envirocbr
could you be a little bit more specific..lol..(i am an idiot when it comes to following directions with out pics) thanks man..
