How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Convert 2 wire signals to 3 Wire Inputs
Old Apr 2, 2014 | 08:16 AM
  #171
Weish's Avatar
Originally Posted by Wranghondo
I did it the way redz shows how to do it and it works just fine. I see no reason to try and find a short cut.
That doesn't really answer my question. I'm not trying to undermine redz how to, it's extremely helpful, I was just looking for someone with some electrical know how to explain why the running light wire needs a diode as well, or if it's really neccesary. I've already got one set of diodes, so I was just wondering if I can make it work with what I have.
Old Apr 3, 2014 | 08:39 PM
  #172
Joshua Rodriguez's Avatar
I was thinking the same thing as you Weish.
I just mounted LED flush signals to front and back. Had no idea of this mod beforehand so now my gauge cluster has both turn signals light on. Wish I saw this thread before mounting them.
anyway im going to buy 4 diodes just in case but only add the diode on the turn signal wires first and then hook it all up and test it. Ill report back here once completed which should hopefully be this weekend or the next.
Old Apr 6, 2014 | 03:49 PM
  #173
You do not need 4 of the diodes, only 2 are required. Just tested it today as I needed to do this mod to fix my turn signals.
What I did:
One diode on the solid blue and one on the solid orange; which are the turn/indicator signal wires. This way the flow of electricity for the running lights up front don't flow back down the turn indicator wire to the gauge cluster, resulting in constantly lit up turn signals on gauge cluster. It also kept the rear turn signals from being lit up all the time too.
Attached is a picture drawn by someone else on another forum but I just added the change to show it. On my LED turn signals the positive wire was yellow and not red. Which may be the same for others.
I also used 1N5401's. Any 1 amp one way diode will work.
Old Apr 6, 2014 | 11:12 PM
  #174
Wranghondo's Avatar
Is it possible that the other diode makes the running light a bit less bright? I haven't paid attention to mine to see if there's a difference.
Old Aug 8, 2014 | 01:07 PM
  #175
troll's Avatar
Registered Users
Will the HotBodiesRacing indicators fit the f4 fairing?
aight
May 1, 2011 02:05 PM
dream95f3
Oct 26, 2010 07:27 PM
stephygee
Dec 22, 2006 01:08 PM
Wheelie Instructor
Nov 13, 2006 06:32 PM
