I'm looking online for a variable load flasher relay and was wondering how many pins. I've seen some with 3 or more. Thanks for the info.
Great right up. Just finished the conversion to integrated mirrors and it works great.
Thanks again. |
Awesome write up I'll have to try it sometime.
what size diode do you guys used????????
never mind....its right at the beginning, i must off missed it. sorry. |
lights are on.
i just completed one side and my blinker stays on like a running light.
it will blink (a bit too fast but i can try to fix that.) surely it doesn't stay on always like a running light??? I believe i followed everything correctly... any suggestions? ----- wow I feel silly, i really just wanted to know what the proper way to hook up 2 wires to 3 wire lights.... i get it now!!! i want to make my (future)audi lights do the same thing so blindly following payed off! |
So ah... You dont want a running light then? You do know that is the whole point of this conversion, right?
here i did the conversion and it worked perfect.
here it is http://www.youtube.com/watch?v=EvUVCmxk9S8 its easy to do. it cost me $22 for the lights and $2 for the diodes. :) |
So now what?
I followed the guide with diodes 1N4001 from Radioshack, and it does indeed turn my Hotbodies flushmounts into both running lights and blinkers. But when I use the turn signal, both left and right indicators on the gauge panel flash. When I apply brake, the lights turn off, AND to top it all off, the rear doesn't blink either. In the rear, I have standard bulbs and I do have the hotbodies blinker box, which speeds up the blinkers when brake is pressed. What can I do?
Horn works
Originally Posted by scorpionvmu
(Post 1018015)
here it is 1998 honda CBR600F3/SJR - YouTube its easy to do. it cost me $22 for the lights and $2 for the diodes. :) |
dude you are the man!
I am in school right now studding electrical engineering and had a blast doing this fix haha! Just curious, what is the difference in the blue and blue-white-stripe wire? Like what exactly are they for? My flush mount came with two wires which are your normal + and - leads. So I figured that the harness (the two blue wires) would be +12 and ground (since the guy selling said it would fit my bike). When I hooked up the lights this way, they stayed on all the time and would turn off when the blinker was selected. I did see the green ground wire on a separate wire, but at this point I didn't want to cut up any of the wires (on either the bike side or the blinker side) so I got online and found this post! also, why do you need diodes on the lines? just curious! thanks man! |
