How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Clutch components
Old Mar 23, 2013 | 08:52 PM
ocarlos5's Avatar
Default Clutch components
This may sound like a stupid question, but I know some of these components have specific measurements and tolerances. Anyway, doing a clutch job on my friend's bike and he bought EBC Kevlar clutch plates and is considering buying Barnett steel plates. Does this matter, or will the bike blow up as soon as I kick it in first? Jk. We want to make sure before he goes out and buys these. He burned up all of the plates in his basket.
Old Mar 24, 2013 | 09:45 AM
backdoc's Avatar
It should not make any difference but I would buy EBC steel plates since he already has their fiber plates. He could have purchased a complete kit that contained all the required fibers and steel plates. It would be hard to mess up a clutch installation and will not blow up the bike even if you do something wrong. If installed wrong the bike will not go in gear properly. Just make sure you soak the new fibers and steel plates in fresh oil before installing them so you don't cause excessive wear on the clutch on startup. Then follow a service manual to install them in the correct order. The steel plates have a smooth edge of one side and squared edge on the other. Install all of them the same direction. I read somewhere to leave the squared edge facing out towards the pressure plate. That's how I installed mine last month when I replaced my clutch after installing a shift kit. Depending on how many miles on his bike the springs probably need replaced too. Do not over tighten the bolts holding the pressure plate. Most bikes have torque settings around 9 ft/lbs for these bolts.
ADRENALINE KID
Aug 30, 2011 05:15 PM
Honda125 358
Jul 12, 2011 12:44 AM
mccannf3
Mar 5, 2008 06:44 PM
ShoHonda
Feb 14, 2007 01:19 AM
diaper eater
Dec 12, 2006 06:40 PM
