How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
929RR/954RR GP Shift Conversion
Old Dec 3, 2010 | 01:56 PM
__Z__'s Avatar
April 2011 Ride of the Month
Default 929RR/954RR GP Shift Conversion
I cannot take credit for this stumbled onto it
regardless good information
These are Honda part numbers for the shifter from a VFR. Using these parts, you can convert your 929/954 to reverse shifting.
Part Number: 24701-MAT-000
Description: PEDAL, GEARSHIF
Part Number: 24781-KR3-770
Description: RUBBER, CHANGE
Part Number: 90051-KS7-830
Description: BOLT, FLANGE
Last edited by __Z__; Dec 3, 2010 at 02:57 PM. Reason: Sorry no other forum URLS allowed
Old Dec 3, 2010 | 02:58 PM
__Z__'s Avatar
k fixed lol better?
Old Dec 4, 2010 | 05:48 PM
letsride's Avatar
You can also get cbr 1100 xx shifter.Also bolt on.
Old Mar 16, 2011 | 08:43 AM
kurtmartin's Avatar
I did this on the 600 and I jsut cut the plastic cover for the sprocket and then I reversed the cam. Not too big a deal and it works great!!
Old Jan 9, 2012 | 12:15 AM
mr manfringinsen's Avatar
The 2005 YZ250 fits nicely as shown below:
It sits a little closer to the peg but I like this.
929RR/954RR GP Shift Conversion-length.jpg
It sits out a bit wider, I may have to modify it.
929RR/954RR GP Shift Conversion-width.jpg
The completed job.
929RR/954RR GP Shift Conversion-done.jpg
I will see how well it sits on the next ride. It sits about three mm lower than I had for the regular shift pattern. If I want to adjust it up or down it goes from one spline to the next. If I adjust it up to the next spline it covers the bottom half of the hole shown in the photo, ie. up approx 15mm. So if I want to adjust it I will have to shove it in a vise and select the correct size hammer. Actually now I think about it I will probably use a large shifter and perform a controlled bend.
Old Jan 9, 2012 | 12:41 AM
letsride's Avatar
The only complaint I have with the yz250 shifter is that the end piece would fold up when I tried to shift.
Old Jan 9, 2012 | 03:39 AM
True, it might. but it comes in handy if you are sliding backwards down the road.
Old Jan 9, 2012 | 12:41 PM
letsride's Avatar
The shifter would be the least of my worries if I'm sliding backwards.
