929RR/954RR GP Shift Conversion
I cannot take credit for this stumbled onto it
regardless good information http://sphotos.ak.fbcdn.net/hphotos-...1_264310_n.jpg These are Honda part numbers for the shifter from a VFR. Using these parts, you can convert your 929/954 to reverse shifting. Part Number: 24701-MAT-000 Description: PEDAL, GEARSHIF Part Number: 24781-KR3-770 Description: RUBBER, CHANGE Part Number: 90051-KS7-830 Description: BOLT, FLANGE |
Zac, yu might have to do something else with those images man ...?
Those are local addresses from your computer for some reason mate ..? and yer I had to edit those URLs out .... I don't make the rulze man ...:icon_wink: |
k fixed lol better?
You can also get cbr 1100 xx shifter.Also bolt on.
I did this on the 600 and I jsut cut the plastic cover for the sprocket and then I reversed the cam. Not too big a deal and it works great!!
3 Attachment(s)
The 2005 YZ250 fits nicely as shown below:
It sits a little closer to the peg but I like this. Attachment 18101 It sits out a bit wider, I may have to modify it. Attachment 18102 The completed job. Attachment 18103 I will see how well it sits on the next ride. It sits about three mm lower than I had for the regular shift pattern. If I want to adjust it up or down it goes from one spline to the next. If I adjust it up to the next spline it covers the bottom half of the hole shown in the photo, ie. up approx 15mm. So if I want to adjust it I will have to shove it in a vise and select the correct size hammer. :icon_smash: Actually now I think about it I will probably use a large shifter and perform a controlled bend. |
The only complaint I have with the yz250 shifter is that the end piece would fold up when I tried to shift.
True, it might. but it comes in handy if you are sliding backwards down the road. :icon_wink:
Originally Posted by mr manfringinsen
(Post 1123504)
