How-To: MechanicalThis section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
So I just bought a 2001 cbr 929 and it won't start at all it is fuel injected but when I turn the key the pump don't even roll over...when I bought it from the guy I got it from it was working fine until we switched batteries and now it's completely dead...please help me
@Jaredmiolen Most likely you popped a fuse for the FI circuit. There is a separate fuse near the battery that is not in the Starter Relay, it's a separate connector with a fuse built into it.
I looked at the relay and it looks like it's been burnt man like the lights or nothing is turning on like there is absolutely no power to it at all
If you're getting no lights or anything, then that would be the 30A main fuse located on the Starter Relay. It's hidden under a small cover. It's right next to the battery.
Remove this cover, there is a fuse located there. It's a 30A fuse. It definitely looks like it blew. You'll need to replace it. If it blows again, then you have a dead short and will need to locate it.
