How To ... This section is to tell 954 owner's How To do something ... not for asking questions ...
CBR 954 Shift Drum and Shift Fork Replacement
Old Feb 26, 2019 | 06:36 AM
CaBaRet's Avatar
Yeh bacdog knows his Hondas, and heres another one to look at ,this guy actually put both springs back in
Honda CBR 929rr/954rr: HOW TO: CBR 929 Factory Pro Shift Kit Install w/ Clutch and Tranny Assessment
Old Feb 26, 2019 | 09:03 AM
backdoc's Avatar
Originally Posted by Rusty43
Pic #9 shows spring tail at 11 o’clock position. That’s 180* more rotation than what I used. I’m installing factory pro shift kit with their heavier spring, and it will be a Royal pain to put that much tension on the shift lever. Does the lever require that much pressure? I’ve seen other photos with the spring tail at 5 o’clock on the shift drum retainer bolt boss.
Check out the pics in the link below on Factory Pro's website showing a shift kit install. You will notice in all the pics the spring installed the same as my write-up. You want more tension on the lever arm otherwise installing a stiffer spring would be a waste of time. The spring and lever arm are installed first, then holding the lever arm up with a screwdriver you install the shift star.
Very good user install write up
Old Feb 26, 2019 | 08:27 PM
Rusty43's Avatar
Default Detent spring
Thank you.
Old May 29, 2020 | 03:52 AM
Thughes33's Avatar
[QUOTE=backdoc;1277319]UPDATE: Since replacing the drum and shift forks a few months ago I have not experienced any missed shifts or the bike falling out of gear. I am also using an air shifter now at the drag strip with great results to ensure no lazy shifts from me. For anyone who is experiencing shifting problems with their 929/954 I would recommend changing these parts before removing the engine and splitting the cases to replace gears in the transmission.
So Backdoc I just wanted to clarify and see if my issues are the same as yours..long story short I was riding down the highway one day and heard a pop and was told that it was my clutch fork so now I can’t get my bike to go into 3rd at all, would me purchasing these parts allow me to fix that issue? Because this far it has been said to me that I just need to purchase a whole new motorcycle engine.
CorruptFile
Dec 30, 2014 01:23 PM
anomalyapparent
Aug 22, 2008 07:09 PM
elmer
How-To: Mechanical
Apr 11, 2008 09:34 PM
cleansho93
Oct 14, 2007 11:14 AM
vtalin
Jul 28, 2005 04:09 AM
