How To ... This section is to tell 954 owner's How To do something ... not for asking questions ...
CBR 954 Shift Drum and Shift Fork Replacement
Old 02-26-2019, 06:36 AM
CaBaRet's Avatar
Yeh bacdog knows his Hondas, and heres another one to look at ,this guy actually put both springs back in
Honda CBR 929rr/954rr: HOW TO: CBR 929 Factory Pro Shift Kit Install w/ Clutch and Tranny Assessment
Old 02-26-2019, 09:03 AM
backdoc's Avatar
Originally Posted by Rusty43
Pic #9 shows spring tail at 11 o’clock position. That’s 180* more rotation than what I used. I’m installing factory pro shift kit with their heavier spring, and it will be a Royal pain to put that much tension on the shift lever. Does the lever require that much pressure? I’ve seen other photos with the spring tail at 5 o’clock on the shift drum retainer bolt boss.
Check out the pics in the link below on Factory Pro's website showing a shift kit install. You will notice in all the pics the spring installed the same as my write-up. You want more tension on the lever arm otherwise installing a stiffer spring would be a waste of time. The spring and lever arm are installed first, then holding the lever arm up with a screwdriver you install the shift star.
Very good user install write up
Old 02-26-2019, 08:27 PM
Rusty43's Avatar
Default Detent spring
Thank you.
Old 05-29-2020, 03:52 AM
Thughes33's Avatar
[QUOTE=backdoc;1277319]UPDATE: Since replacing the drum and shift forks a few months ago I have not experienced any missed shifts or the bike falling out of gear. I am also using an air shifter now at the drag strip with great results to ensure no lazy shifts from me. For anyone who is experiencing shifting problems with their 929/954 I would recommend changing these parts before removing the engine and splitting the cases to replace gears in the transmission.
So Backdoc I just wanted to clarify and see if my issues are the same as yours..long story short I was riding down the highway one day and heard a pop and was told that it was my clutch fork so now I can’t get my bike to go into 3rd at all, would me purchasing these parts allow me to fix that issue? Because this far it has been said to me that I just need to purchase a whole new motorcycle engine.
CorruptFile
12-30-2014 01:23 PM
anomalyapparent
08-22-2008 07:09 PM
elmer
How-To: Mechanical
04-11-2008 09:34 PM
cleansho93
10-14-2007 11:14 AM
vtalin
07-28-2005 04:09 AM
Quick Reply: CBR 954 Shift Drum and Shift Fork Replacement
