Y anchor ftw!!
Old Oct 14, 2011 | 01:07 PM
coldflood's Avatar
Default Y anchor ftw!!
dundundundun!!!
Anyone know how to install these can't figure out how big of a hole i have to dig
Old Oct 14, 2011 | 06:41 PM
MadHattr059's Avatar
Basically the hole needs to be as wide/long as the top of the anchor.
You'll need to widen perpendiculaly at the center to accomodate the cross-pin.
If you are mounting in a slab you'll want to be fairly close, just to avoid
extra work. Leave just enough room to back-fill the concrete.
If you are mounting it in the ground, I'd do a hole about a foot bigger in
dia than the length of the top, about 6" deeper than it is tall. Then drive a
couple of pieces of re-bar at opposing angles in the bottom of the hole,
leaving about 4-5 inches out of the dirt. Level the whole assembly (flush to
the ground) and back-fill concrete around the re-bar/anchor to full.
If you wire a board on top of the mouth that's wider than the hole, that will
support it till the concrete sets. Then just nip the wire off flush to the new slab.
These are best used in a rain/water sheltered place as there is no way to
drain any water that accumulates in it.
Ern
Old Oct 14, 2011 | 07:10 PM
coldflood's Avatar
Could u like draw what u mean, like specs on a paint document that would really help, im not sure what you mean by rebar. Are there any similiar items sold in the US to this? Also, its going to be one the side of my house. Thats kinda sheltered I guess. Plus they tell you its got a hole on the bottom to let it drain idk how well that'll work.
What I planned on doing was just digging a hole bigger than this thing and filling concrete around it. I like the rebar idea just dont fully understand it.
Old Oct 14, 2011 | 10:06 PM
Ern's instructions seemed to be right on. Rebar is short for Reinforcing Bar. It's steel bars with a bumpy pattern on it that helps add strength to concrete. The bumps help the concrete "Grip" the steel. You can pick it up at most building supply places like Home Depot and Lowes. This is what it looks like. I'm sure you recognize it now.
Old Oct 15, 2011 | 05:58 AM
If you wanna go inexpensively... Buy a length of chain, dig a hole. Get a 4 foot piece
of rebar and bend it into a giant staple. lay the middle of the chain in the hole, drive
the staple on top of it, down into the bottom of the hole. Fill the hole with the chain
drapped out of the edges. Mound the concrete slightly, to shed water and you are
done. The product you are looking at is designed for a garage floor, so it will not have
anything above floor level.
Ern
sluijs01
How-To: Mechanical
May 16, 2013 06:47 PM
sluijs01
May 8, 2011 04:38 PM
woo545
Jan 28, 2008 11:18 PM
