wiring sat nav
Evening all I have a questions with regarding a sat nav ( TomTom rider 550 ) and where to place the wiring for it as i don't know where to place it in the bikes wiring loom or directly to the battery on a 95 CBR 1000F
I ran my accessory positive feed from the post on the starter solenoid/fuse - it was neater than having a bunch of wires around the battery. The ground can go anywhere on the frame - it does not have to end up near the battery.
starter solenoid/fuse is that the starter relay and if so when ignition is turned off does the sat nav not charge or does it still charge. and you don't by any chance of a picture of the starter solenoid.
i did look online and there was about 3 different images 1 for the 600F and 1 for the 1000F and a plug style relay and i also looked at the wiring harness image and it wasn't there so i had to look in the Haynes manual and found it
