wiring HELP ASAP
Old May 14, 2011 | 06:17 AM
prodkey05's Avatar
Default wiring HELP ASAP
I recently had an accuse t with the bike due to weather blowing it over. I tried hooking up flush mounts and an integrated tail light but no luck. I know I must need resistors or a relay cause they will light up but not flash. PLEASE HELP ASAP. Thanks in advance
Old May 15, 2011 | 11:39 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
If the lights come on but will not flash at all there is another problem other than adding resistors or an LED relay. Without those and just the stock relay the lights should still flash but at a much faster rate. You might want to check your wiring first with a multimeter.
When you get ready for an LED relay check out the one below. I have the LF1-S-FLAT and it plugged right into my OEM connector. Scroll down to the bottom of the page for the motorcycle applications.
LED Flasher Relays
ICEmonky
Jan 4, 2011 06:54 PM
one_sick_stang
Sep 14, 2007 12:45 AM
mastice
Nov 26, 2005 04:37 AM
