Where can I buy those damn o-Rings?
Hello there,
I have a leakage of coolant/fuel due to damaged o-rings. Its a vary small part but stopped all my project. I badly need to buy them but I cant find them anywhere. BikeBandit wants like $15 for a set and two sets are required!!! I checked HomeDepot and Advance autoparts store with no luck. There are very cheap and can be found in bulk online but I dont know the size. If anybody could help me out with that.... I dont want to buy new carbs ((((
http://fiche.ronayers.com/Index.cfm/...ARBURETOR_ASSY
Part #9
Thanks!
Part #9
Thanks!
Im not sure of the size, but you need to be careful when buying o-rings. Not all O-rings are the same material and may not hold up to what your using them for. Some cannot take chemicals and heat. More than likely the reason they are more expensive is the material they are made out of.
My suggestion would be to order the proper ones for your bike, otherwise you may end up regretting it later on. If you do end up buying cheap ones, make sure they can handle the heat and chemicals they will be exposed to.
