$200 0-rings
Old Jul 28, 2007 | 07:05 PM
airick's Avatar
Default $200 0-rings
Hey guys,
Got the bike back up and in tip top shape. Thought it was the head gasket so took out the engine swaped the head gasket checked the valve clearances(all were good) Put the engine back in to the bike and fired her up ( 3 days worth of labour and $200 in parts and tools and oil and honda antifreeze and a filter.) fired her up and what do you know there is oil in my coolant again #%@)#&! so the only other place oil could be getting into the coolant was the oil cooler. took off the cover and the heat sink for the oil and what do you know, the two o-rings on the inlet and outlet of the heatsink were basically gone. So a trip to the honda dealer for o-rings was fruitless. would have had to wait a week for them. went to menards and as luck would have it they had the exact two i needed that were a dollar for two. I put the oil cooler back together, filled the coolant, topped off the oil, and what do you know it works. 3 days of labour and $200 bucks for a one dollar fix and 15minutes. Haha. What can you do...
Old Jul 28, 2007 | 07:34 PM
sstgonzo's Avatar
Default RE: $200 0-rings
where did you find that carbon fiber front fender?
Old Jul 28, 2007 | 08:31 PM
airick's Avatar
there is one on ebay right now
http://cgi.ebay.com/ebaymotors/Used-...spagenameZWDVW
if the link doesn't work search ebay for "f2 carbon fiber front fender"
Old Jul 28, 2007 | 10:32 PM
bmg velocity's Avatar
ORIGINAL: airick
Hey guys,
Real simple solution.
Tell the parts and service head, and owner of the shop that the $200 you spent will go towards the bill when they fix it right.
If they give you any problem, just tell them, in a calm voice, this is business afterall, tell them that failure to do so will result in much more damage by word of mouth than $200. Tell them you'll make it your daily activity to recommend to anyone who rides not to frequent there.
Ask them if that's a deal.
If it's not...make good on your threat, and go somewhere else for your servicing.
I got so fed up with my local Honda shop, I went to one 30 miles away. They did things right. I watched.
The other guys, the local guys, changed two tires, and by the time I got home the chain adjusters had nearly fallen off.
In short...
Honda of Decatur = Good
Honda of my city = crap...
Also, inform them that you'll be writing a very formal letter to Honda Motor Corp. (Japan)
Send it special delivery.
That local shop will have angry, samurai sword swinging CEO's out the ying yang.
Honda Corporate does not f*** around.
Old Jul 29, 2007 | 07:35 AM
410600f2's Avatar
Will the 03/04 fender you posted fit thef2
Old Jul 29, 2007 | 11:38 AM
airick's Avatar
sorry i didn't see that. the f2 versions pop up on ebay every once and a while just keep an eye out
Old Jan 3, 2008 | 02:10 PM
redcbrman's Avatar
So. I just did the same thing.
Ripped apart my entire head, ordered new head gaskets, accidentally ruined my cam timing sprocket and timing chain in the process. Ordered new ones of those.
Then, just for ****s, I looked at the oil cooler, and the O rings are shot. Goddamnit. lol
So now I just need to figure out where to buy those O-rings.
Old Jan 3, 2008 | 04:11 PM
CajunCBR's Avatar
I had the same problem. Except I compression checked the cylinders and confirmed it wasnt the head gasket. That narrowed it to water pump, or oil cooler. Went to oil cooler first since it was easy and same deal.
Honestly I would recommend to anyone who hasnt changed the seals in the oil cooler to do all of themyour next oil change. Its like$15 for two gaskets and two o-rings, but worth a hell of alot more to not be stranded, and to not have to flush/clean the system. The gaskets go between the two halfs of the cooler, between the cooler and block,and the o-rings go inside it.
Old Jan 4, 2008 | 07:50 PM
redcbrman's Avatar
Where did you get your O-rings?? I was doing a compression check but was #$)@ing stupid and had the chain ziptied up when I did it. Now I wish I had done the compression check loooong before I even opened up the top.
On the slightly bright side, Ill have basically a rebuilt engine after this that I shouldn't have to worry about for a good long time.
Old Jan 5, 2008 | 08:35 PM
CajunCBR's Avatar
I just got them from the dealer when I ordered the rest of the gaskets.
michealparks
May 28, 2024 09:50 AM
john lindley
Jul 8, 2014 04:38 PM
Monkeybutt2000
Oct 4, 2011 12:48 PM
buickid
F2 Tech
14
Mar 13, 2011 06:27 PM
CyberTrip
Alternative Parts
Jun 2, 2010 01:08 AM
