When to replace the clutch?
Old Dec 9, 2007 | 01:40 AM
demonchild's Avatar
Default RE: When to replace the clutch?
no.
Old Sep 30, 2008 | 07:23 PM
FLYOU's Avatar
[:@]sorry. unintentional bump...
Old Sep 30, 2008 | 10:44 PM
rellimdekim's Avatar
I would replace the clutch. I use to be able to tell when I couldnt power wheelie anymore. Just make sure you soak your friction plates overnight before putting them in. Also make sure you tighten everything to the correct torque spec. Its a really easy job, and your bike gets some new oil too. Win Win situation.
Old Sep 30, 2008 | 11:29 PM
pacemaker's Avatar
Not disagreeing about your need for replacement, but a couple of things to do (actually just one, but..) Do an Oil change, make sure the motor is at running temp, check the old oil for any debris which will look likes bits of fibrous material (& old cardboard) suspended in the oil, a sure indicator your clutch is RS.
If no crap in your oil, it may be the old oil was passed it & the new stuff may fix your problem.
Old Oct 1, 2008 | 08:28 PM
Hatebreed's Avatar
if the clutch was just abnormaly hot it could be doing that... try it again. get on the freeway cruise at mif to high rpm and pin it.. if it slips change it if it doesnt dont.. sometimes whne the clutch just gets hot... itll be very soft.
Old Oct 1, 2008 | 09:09 PM
Nauree's Avatar
quit reviving dead posts.
Old Oct 1, 2008 | 10:13 PM
TK954RR's Avatar
Jan 2009 ROTM
Fly did it on accident i think, but others sure chimed in quick without checking the date. Anyhow POST IS DEAD NOW.
Old Oct 2, 2008 | 08:57 AM
Northernfirepower's Avatar
ORIGINAL: Nauree
Should I get a new clutch spring cause springs get weak over time.
Those springs alone were the only parts out of spec when I replaced my clutch in the F4i this summer. And it makes good sence, low spring pressure can cause slippage. I't not too hard of a tear down, so if you can afford the down time, I'd take apart the clutch parts and spec them to see what is and isnt in tollerance, then order ur new parts
Edit: damnit, didn't see this was a thread of the past!
Mr. B
Oct 15, 2010 12:59 AM
JonBrown
Sep 19, 2010 05:44 PM
jurkey77
Jun 23, 2009 10:05 PM
lepto
May 30, 2009 07:27 PM
JonBrown
Oct 7, 2007 12:37 PM
