When do you change your tire?
ORIGINAL: swe39
Are tires bad if there are many cracks in the rubber in/around the grooves?
There are many indicators that tells you when to change your tire.
Tread (or lack thereof) is the most obvious. The short of it is don't wait until your tires are bald...much less have corded spots. Cords = no traction. Enough said. Your tires were never designed to be run while bald...don't let it get there. Technically what denhaou said is true and the ideal way to do it. I don't really measure though...when the tread pattern gets to be more of a suggested design, it's time to change, imo.
Now one thing that many people don't think of is the hardness of the tires and/or dry rot. Tires can keep their tread for a very long time, especially if you don't ride very many miles each year. The tires on my F4i when i bought it were about four years old (you can tell when they were manufactured by the number molded in the sidewall - four digits with the first two being the week and the last two the year), but they still had a good 1/2 tread left on them. They even warmed up ok and were fairly sticky...so i didn't *have* to replace them, but i did and it made a world of difference. They were so flat spotted...
Anyways, my point is that an old tire can get so hard that it needs replacement even if it has a decent amount of tread left. And how do you know when to replace it? Well, you'll just have to make that call on your own. If there are visible cracks, replace it for sure...the rubber's breaking down. Other than that, well...how safe do they make you feel?
on
1 Post
I change mine when it hits the wear indicators, I'm not going to dick around with a real safety issue for a few bucks. Besides, when I ride I want to be in a good mental state (rather than a state mental) & not worry about tyres (as in grip), I'm even **** enough to check the tyre pressures before I ride (I have a digital tyre gauge key ring) Plus I really enjoy scrubbing in a new tyre.
I change my tires before the tread shows. I have had a few tires at the wear limits start to bubble and I've had one tire blow on acceleration... they just aren't made to be worn past the wear limits and certainly not on the thread. I have limped home on a tire showing bubbles and thread... but I can tell you that I was using next to no throttle and no rear brake. I took a long time to get home.
I change tires if they are 3 years old - even if they aren't cracking. On the flip side I've never had a tire I've installed last 3 years.
