what is wrong with the starting?
Old Aug 31, 2007 | 01:12 PM
corteztk1982's Avatar
Default what is wrong with the starting?
so my bike that i have been trying to get running is turning and trying to start, makking a chugging but just wont kick in. i sprayed some starter fluid in the carbs on multiple occasions and gave it gas a lot but dont want to flood it and it still wouldnt fire up. i could tell that i think the spark plugs were working because i could see exhaust being expelled from the carbs clearly enough to see what the firing order was. im just at a loss of what is wrong here
Old Sep 1, 2007 | 02:24 PM
demonchild's Avatar
Default RE: what is wrong with the starting?
You are not getting spark. If you are spraying start fluid in the carbs or air cleaner, the bike should momentarily start and then die.
Old Sep 1, 2007 | 08:02 PM
what do i do to fix this?
Old Sep 1, 2007 | 09:40 PM
1fasthonda's Avatar
Depending on how old and mileage wise check the valve clearance.
Old Sep 2, 2007 | 05:59 AM
fishfryer527's Avatar
Starting fluid will wake the dead, My money is with Demonchild, no spark.
Old Sep 2, 2007 | 11:24 AM
no compression
Old Sep 2, 2007 | 10:53 PM
demonchild's Avatar
I would be hard pressed to believe that compression or valve clearance has anything to do with it unless someone was inside the motor messing around. Check for spark first to confirm a no spark situation. If there is no spark, message back and I will try to help you troubleshoot.
Old Sep 3, 2007 | 12:57 AM
there is spark and fuel. but theres no comnpression in there. not even any exhaust pressure
Old Sep 3, 2007 | 07:47 PM
demonchild's Avatar
Exactly how did you do a compression check?
Old Nov 18, 2007 | 09:53 PM
tripicana's Avatar
i just bought a 87 CBR600 and it wont start either. it turns over and has spark. what should i check next? will an automotivecylinder compression gauge work,or will i need a special adapter? any links how to check the valve clearances? thanks
