What are using to lift your bikes?
Old Mar 22, 2013 | 05:34 AM
wrongway's Avatar
Registered Users
Default What are using to lift your bikes?
I was going to buy a pitbull hydraulic lift to work on a the 1995 CBR900 and a HD sportster. However, I don't think the PB lift will be able to lift the CBR because its headers protrude below the frame. Any alternative lift suggestions?
Old Mar 22, 2013 | 07:49 AM
I think paddock stands are the way to go for your 900. Depending you what you get, they should work for the Harley as well.
Old Mar 22, 2013 | 11:47 AM
Kuroshio's Avatar
Would recommend against the hydraulic lift. Used something similar on my F3. It's possible. But I was never comfortable with the stability.
Old Mar 22, 2013 | 12:21 PM
Funkymonk's Avatar
You can't go too wrong with a decent pair of paddock stands mate, I use them all the time for mine.
Old Mar 22, 2013 | 12:45 PM
74demon's Avatar
The sportster will work well with the hydraulic lift. I use one to lift my Harley.
The 900rr is a different story. I use a paddock stand for the rear, and a pulley from a garage beam to lift the front.
Sorry, but two different lifting methods for two different bikes is required.
Old Mar 22, 2013 | 04:42 PM
Conrice's Avatar
i use:
this
this
depending on what i'm doing
Old Mar 22, 2013 | 05:44 PM
wrongway's Avatar
Registered Users
OK - maybe in not seeing something here, but if I need to pull the front forks on the CBR - I couldn't use a paddock stand - what would you use?
Old Mar 22, 2013 | 06:03 PM
74demon's Avatar
Hang it from the ceiling. That's what I do. Strap around the frame and neck and pull the front up. The front is not that heavy.
Old Mar 22, 2013 | 07:17 PM
Kuroshio's Avatar
Pitbull headlift stand with the standard pin + #1 adapter is supposed to work with the CBR900 up to 1997
Old Mar 22, 2013 | 08:06 PM
cBrentb's Avatar
ratchet straps to the rafters to lift front
